just fitted ramair induction and a light has come on!!
could it be the breather pipe you mean? That's the only thing I can think of that's attached to the top of the airbox.......usually put a small filter on it if you replace the airbox with an induction kit.....
adiohead
296
england
www.zetecs.com
but the plug is attached to the top half of the air box!!
the air box you removed?
you need it to look like the picture posted above, and this one:
this 1.6 ibiza guide might help:
http://www.seatcupra.net/forums/showthread.php?p=2156067
cupra.rich
172
yeh ive done that now cos i managed to get the plug part off the box and put it inbetween the induction kit and the other pipe but i still have these two lights on..
The red one is for low brake pad warning, the one with the arrow is because your traction control is turned off.....I would hazard a guess that the engine light is on because of having the MAF unplugged a while but someone else may know better......
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
if youve run the car with the maf unconnected or hanging around then its more than likely that. make sure you know your radio code first.. but you could try disconnecting the battery for 10mins. it may clear the ecu
cupra.rich
172
the red one is because i have the hand brake on! the other explantion mark yellow one isnt to do with the TC because i keep pressing the traction control button and its not going away or flashing etc. will unplugging the battery work?? i do know the radio code.
cheers
rich
cheers
rich
probably means you have a fault with your TC then as that IS the TC light.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
i think mafs causing both lights (no idea why it flags tc :confused: but if memory serves it should fix both)
if disconnecting does`nt work you need vagcom software to clear the faults but im pretty sure the battery should work.
cupra.rich
172
i always thought that the newer the car the easier they are to fix and such, never once had a problem with my scooby. lol
o well i will go and unplug the battery and let u all no
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
cmon mate .... user error rather than car error;)
it thought your maf had died and was urgently trying to send you for repair... clever little sausage that she is.
cupra.rich
172
u lot are funny fu**ers arent u! lol so all of your maf sensors where attached to your air box's aswell then??
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
just to clarify.. you took out the black stock air box, including the maf pipe unclipping the electrical connection and leaving it free?
youve now taken the maf pipe off the old airbox fitted it as you describe and plugged the electrical connector back in?
cupra.rich
172
yes! just reconnected the battery and the engine light has gone and so did the TC light but after a minute the TC light came back on! any ideas???
also if i bought vagcom would it tell me exactly what the fault is etc?
rich
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
youd get a code which relates to a sensor. useful bit of kit.
have a good look around where youve been working.. have you knocked anything?
cupra.rich
172
dont think i knocked any thing.... is there anything in that area that i could of knocked which would affect it?? also is that light only for TC?
