just a few quick questions
CHR15B
2,567
9
Scotland
Incase you want to disable the feature with VAG-COM or if someone else who finds this wants to, I've outlined the steps to do it below.
Turn on ignition, start up VAG-COM...
Go to "Select control module" from the main menu.
Select "46 - Central conv."
Click on "Adaption - 10"
Press "Up" next to channel number and watch for "Auto Lock" at the top.
When found Auto Lock, set "New Value" to '0' from '1' click "Test" then "Save"
Press "Up" next to channel number and watch for "Auto Unlock" at the top.
When found Auto Unlock, set "New Value" to '0' from '1' click "Test" then "Save"
Then click "Done, Go Back"
Remove key from ignition then the next time you start up those annoying locks won't bother you.
On the same screen you can also find the Lock/Unlock Chirps too, and adjust using the same manner.
Also to disable selective locking (One press unlocks all doors and boot, rather than one press for drivers door then another press for the rest) follow the instructions below...
Click on "Recode - 07"
The number in at present will be a even number, add one to that number to make it an odd number then click "Do It".
Remove keys from ignition and lock the car - the next time you go to unlock pressing the unlock button will unlock everything.
I've disabled both on mines - found them more hassle than handy.
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
thants awsome, all i need now is a VAG-COM!!
st10587
Oct 4, 2007
3,669
Hindhead
Regarding the lack of acceleration went out last night and noticed that it seems to be smoking when it wasn’t before! Slightly worried now :confused:
st10587
Oct 4, 2007
3,669
Hindhead
ok the FR gone in to the dealer today to get the few problems sorted but look what they gave me to run round in......
:cry::cry::cry::cry::cry::cry::cry:
so not impressed by it
muddyboots
Still hanging around
Oct 16, 2002
5,739
You should think yourself lucky, I'd be happy with that!
I used to get a 1.0 Arosa as a courtesy car...
st10587
Oct 4, 2007
3,669
Hindhead
i would be happy with it if they had given it to me clean and in one piece. theres trim layin around all over the place ane is filthy inside and out
st10587
Oct 4, 2007
3,669
Hindhead
ok got my FR back, both front fog lights replaced under warrenty, boost pipe replaced as old one was leaking, various rattles tweaked on the inside and in the engine bay............but its gota go back in a couple of weeks to have osf fog replaced again as it had misted up by the time i went to collect it, its also having to have the dash removed to cure the rattle in the dash as they think its behind it:-o and a new rear wiper arm as the rear wiper in not clearing the screen after a new blade was fitted!!
