Jenk's purple mk2 track hack...Im sure it hates me
Feb 20, 2005
3,476
Telford ay it...
MOT booked for Saturday, I am slightly pooping it as I always do. ABS is randomly playing up again and I've found another hole :doh: My uncle will be round for the second time in 2 weeks, lucky for me he does the welding for a cup of coffee and a biscuit :D
Feb 20, 2005
3,476
Telford ay it...
Guess whats lights apeared today whilst doing my final pre MOT checks? :censored:
Up with the sun rise tomorrow to hopefully fix it, MOT's at 9am :(
Everyone pray for jenk!
Feb 20, 2005
3,476
Telford ay it...
Cheers! If the tester finds any more rust I'll slap him!
Its the ABS thats causing me concern now, I think the wire has gone to the rear right sensor. Tested with a multimeter and the voltage through it is virtually nothing. If it is the wire thats buggered I can hopefully do a temp fix with what little time I have in the morning.
Feb 20, 2005
3,476
Telford ay it...
It seems to much work to remove it, new pipes, bias valve for the rear, pissing about with getting the bias right etc. etc.
I'd rather buy a Westfield :happy:
vngtx
hmmmm poke MOT testers eye so he cant see pump? ;) does it have any bearing noise? could be ABS ring. but not sure what type of ABS the beezas have.
Feb 20, 2005
3,476
Telford ay it...
Failed :(
ABS logged one single fault while it was in the garage, no problems there or back! I was up at 6am this morning to fix it, I think I can solve that now.
Emissions was the other one, idle was ok but failed fast idle. Got a week to try and sort it.
I'll start a thread for that as its something its always had a problem with come MOT time.
Everything else was fine and dandy, so im kinda happy about that.......just two silly things, and the one is fixed already!
Feb 20, 2005
3,476
Telford ay it...
Im going to stick a fuel treatment in when I go back and thrash it like a good'un.
Changed the oil and filter when I got back yesterday, its had a new fuel filter and other bits checked over. Plugs, leads etc look in good nick. Plugs do look a tad white though, suggesting its running lean?
Choosey
My mk2 failed it's MOT in April and has been sitting around since then. This thread's just given me an my mate some inspiration to get it sorted for track use! Looking good mate. Any new pics to show at all or is it still in the same guise as before?
Cheers,
Lee
Feb 20, 2005
3,476
Telford ay it...
Cheers mate, its not changed much on the looks front so no pics. Once its running well (if ever) I'll start tarting it up a bit, still wouldn't mind some colour on the wheels......although the black and purple combo is growing on me.
Feb 20, 2005
3,476
Telford ay it...
Failed the retest :cry:
By magic, the ABS light came on when the tester pulled it into the bay. Then turned back off again as I got in the car to take it away.
Not much change on the emissions either.
Feeling as though I should call it a day :(
Feb 20, 2005
3,476
Telford ay it...
Yes mate, here you go.
Fast Idle
CO - 0.479%
HC - 20ppm
Lambda - 1.005
Second Fast Idle
CO - 0.419%
HC - 13ppm
Lambda - 0.997
Idle
CO - 0.466
No idea whats wrong, hopefully not the CAT as thats expensive.
