James' LCR - 2008cc Stroker HTA GT3071r! - Tuned @ Badger5
Ronin225
4,652
22
Worcester
Have you kept the block to chassis earth or removed with all the old wiring as this could cause your problems
I did it on Phill's car so check/make up a new engine to chassis ground
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Looks good mucka on the wheels
Have you extended the maf wires yet?
Didn't get round to the wiring i'm afraid.
I did check the earth, infact it is earthed in 2 points.
Going to test all teh coilpack connections with a multimeter and see if there is a problem there.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Monday,04,February,2013,12:11:56:36838
VCDS Version: Release 10.6.2
Address 01: Engine Labels: NONE
Control Module Part Number: 1ML 906 032 A
Component and/or Version: 1.8l R4/5VT 0001
Software Coding: 10510
Work Shop Code: WSC 79927
10 Faults Found:
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 -- 35-10 - - - Intermittent
16397 - Bank 1: Camshaft B (Exhaust): Position Actuator Malfunction
P0013 -- 35-10 - - - Intermittent
16697 - Misfire(s) Detected; Reason: Lack of Fuel
P0313 -- 35-10 - - - Intermittent
16691 - Cylinder 7: Misfire Detected
P0307 -- 35-10 - - - Intermittent
18024 - Glow Plug Pre-Heat Indicator (K29): Short to Plus
P1616 -- 35-00 - -
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
P0135 -- 35-10 - - - Intermittent
16702 - Rough-Road Torque Limit Signal from ABS: Electrical Failure
P0318 -- 35-10 - - - Intermittent
17651 - Fuel Injector for Cylinder 7 (N85): Open Circuit
P1243 -- 35-10 - - - Intermittent
17653 - Needle Lift Sensor (G80): Short to Ground
P1245 -- 35-10 - - - Intermittent
17649 - Fuel Injector for Cylinder 5 (N83): Open Circuit
P1241 -- 35-10 - - - Intermittent
Readiness: 0010 0000
GRRRR!! Bloody cars! So it thinks it's an 8 cylinder diesel by the looks of things lol
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Wow surely all those aren't ACTUAL problems with the car. Must all be triggered through one open connection or something?
Shame you couldn't clear them.
Dec 25, 2009
1,531
If we LCR owners were closer you could have borrowed my VAGCOM & would have given you a hand.. Hopefully just a case of deleting errors and nothing comes back ;)
Dec 25, 2009
1,531
Had a Passat once, wasnt running right at all after the garage did clutch change as various sensors etc were disconnected for the job, now as soon as i cleared the faults the car ran bang on! So hopefully yours should be ok after the fault code deletion too :)
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Tried to start the car, won't fire! Cranks but no start. No fault codes
