James' LCR - 2008cc Stroker HTA GT3071r! - Tuned @ Badger5
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
it has fuel=damp petrol smelling plugs
it has ign feed to coils=checked 12v to its respective earths
does the engine see rotation to know to fire? guessing so if injectors are firing and wet, but not spark?
dry the plugs, try warming them... and try again
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
checking voltage at coil during cranking may reveal an issue..
seen that before - wiring earths were the issue then
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
James how did you get on bud?
Spent all day on it mate. Tested everything!
Moved battery up front
Tested all the coils
Tested all the wiring
Checked all the earths
Created new earths
After what felt like testing everything bill suggested checking voltage on the coils at cranking... 10V! It appeared to be dropping voltage between ignition and cranking, so traced all the wires insulated everything again and tried again... Same problem. Decided on a whim to change the NEW BKR7EIX plugs I had in it for some BKR8EIX plugs I had sitting around and wham fired first time!
Had me completely stumped and the only thing I could put it down to was a bad batch of plugs... These where bought brand new from opie so they will be getting a snotty email shortly.
Anyway glad it's all fixed, doesn't throw any codes and runs like a dream.
Managed to get it outside to put the r32 seats in and tidy up the mess I had left behind. All in all, a long, stressful day but glad its sorted.
1,531
From foooooooking plugs, does happen sometimes but not all four! Glad you back on road mate :) Passenger ride in this needed one day ;) lol
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Good work mate, annoying you had to cover all those bases but it's good to to know what state all of that is in also.
Dodgey batch of plugs then or maybe damaged in transit maybe. Who knows. Either way, I'm glad she's alive again :)
