rtrotter
Need to change transmission fluid at the weekend, garage that did the clutch have used something too sticky and the recent cold weather is starting to make gear changes quite tough until warmed up.
Just want to make sure I have everything to hand before starting as I don't want to be stranded with an empty transmission!
Is the circled hole (with and without plug) in this O2M the fill hole, I know where the drain is on the bottom with the ridiculous socket - i haven't got round to checking which type so I don't know if its the security type or now yet.
And I guess it's just a fill till you reach the hole kind of approach - any ideas on amount - I would guess between 2 and 3litres?
Lastly, will be aiming to get hold of some Redline MT-90 as this seems to be the fluid of choice in a lot of VAG forums for this gearbox. Any ideas where I might find this in the UK, will it need to be mail order? Anyone suggest something alternate that I could pick up from halfords/garages etc.
Thanks very much in advance for any help.
