Is the Seat Strut Brace worth £50?
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
thats it on my car hope this is what your were loking for
show off :harhar: :harhar:
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
i ordered my stut brace today av it!!!!!!! but cant have it till christmas might have a peek what it will look like tho!
Kendo
The Kit Car Man
May 15, 2005
329
erskine
put some washers under the n/s strut 13mm bolts, should hold it slightly higher then you wont get this rattle!
Thanks very much think I will as its now getting on my :censored: . Are the bolts long enough to accomodate the strut brace and washers or should I put longer bolts in?
rashcupra
Oct 15, 2006
6,517
crawley
no origional bolts are long enough just put enough washers on till it clears! 2or3 but make sure bolts get a good few turns in thread!!
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
washers? eeek I just bought 1 off ebay can anyone just confirm all I have to do is remove the bolts on flat ground and out the strut brace in replace em?
and where do I put these washers inbetween the brace and the suspension or am I just using them to protect the strut brace and putting them between the bolts and brace.
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
you put the washers under the brace between the it and the mounting point(but i didn't bother as mine doesn't rattle on the air box), and yes just remove bolts put in place and put bolts back, it' that easy (just two of the three bolts tho :))
EDIT: just read you have the 1.2 so you shouldn't need washers as the engine doesn't move as mush as on the bigger dervs and petrols
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
no probs,
just check on the pic above that i posted an you'll see how close the airbox is to the brace on the FR's
it's the bit i've marked the screws up on
rashcupra
Oct 15, 2006
6,517
crawley
you might not need to as davels has said but the washer idea is simply to raise the strutbrace to avoid the brace rattling on the airbox and engine cover but is still as simple to fit obviously!
just without the bodges ive heard to stop the rattles
gazjones
1.2 is fine no need to space it at all there is nothing near it to hit it
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
ok cool done it, without washers mainly as there wasnt any and as gaz says didnt see the need on a 1.2. O and btw lads got it pretty cheap forgot 2 mention £30 incl delivery was second hand arrived in very good condition, ebay aint it great posted link to item below. (o and thanks if it was 1 of u lot selling it on here)
Strut Brace
rashcupra
Oct 15, 2006
6,517
crawley
looks pritty damn tight to the air box no rattle noises no?? might just be the angle of the picture did you try washers in the end ???
Kendo
The Kit Car Man
May 15, 2005
329
erskine
Is pretty damn tight. Only rattles for a second on acceleration. Not tried the washers yet. Its been raining for about 6 months up here in Scotland. Once the week of summer comes around next august will fit the washers.
rashcupra
Oct 15, 2006
6,517
crawley
it will only take the time to undo 4 bolts easy acess and will stop that noise on take up! lazy LOL :)
