Ibiza Cupra Logs
L.R.C.
234
Last week my battery went dead...
I bought a bosch silver, hook my vag-com, cleared all dtc's, i did a TBA and went for a log (my 1st ever!!)
Specs:K&N panel filter(no oil),Full 63.5 exhaust with racing cat and 2 silencers,Custom FMIC with S3 style piping,Custom Map,Forge DV006,N249 Bypass,4bar fpr and 102.000km
3rd gear runs:
Code:
[B][U]Group A:	'002[/U][/B]
RPM	Load	Inj. On Time	Mass Flow
/min	%	ms	g/s
1200	65.4	7.38	15.69
1480	73.7	9.43	21.47
1760	81.2	10.25	29.00
2160	96.2	11.89	41.81
2600	118.0	15.58	60.75
3200	159.4	21.73	102.22
3840	163.9	22.96	119.08
4400	148.9	20.91	122.50
4880	136.1	19.68	126.61
5280	125.6	18.45	126.89
5640	117.3	17.63	125.28
5960	111.3	17.22	125.72
6240	106.8	15.99	127.72
6480	103.0	15.58	128.17
[B][U]Group B:	'115[/U][/B]
RPM	Load	Absolute Pres.	Absolute Pres.
/min	%	mbar	mbar
1240	16.5	970.0	1000.0
1280	66.9	1170.0	1050.0
1560	75.9	2140.0	1120.0
1880	83.5	2140.0	1250.0
2280	103.8	2120.0	1490.0
2800	130.1	2080.0	1910.0
3440	166.2	2040.0	2420.0
4040	157.1	2040.0	2260.0
4560	145.1	2010.0	2020.0
5040	133.1	1970.0	1890.0
5440	122.6	1970.0	1770.0
5760	115.0	2000.0	1670.0
6080	109.8	2030.0	1590.0
6320	106.0	2020.0	1540.0
6560	102.3	2030.0	1510.0
[B][U]Group C:	'020[/U][/B]
TIME
CF	CF	CF	CF
0.0	0.0	0.0	0.0
0.0	0.0	0.0	0.0
0.0	0.0	0.0	0.0
0.0	0.0	0.0	0.0
0.0	0.0	0.0	0.0
0.0	0.0	0.0	0.0
0.0	0.0	0.0	0.0
0.0	3.0	3.0	0.0
0.0	3.0	3.0	0.0
0.0	2.3	2.3	0.0
0.0	2.3	2.3	0.0
0.0	2.3	2.3	0.0
0.0	1.5	1.5	0.0
0.0	1.5	1.5	0.0
0.0	0.0	0.0	0.0
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Agreed, I was pulling 158g-s with a simlar spec. (When running k03)
Also 4th gear is better to log, So i have been told anyway.
L.R.C.
234
OK about the maf...
whats your opinion about the requested and actual boost?
L.R.C.
234
Cleaned MAF and AIT sensor, then i log 3rd gear run... (only prob is the unleaded 95ron)
Code:
Group A:	'002
/min	%	ms	g/s
1240	9.0	1.64	2.25
1320	58.6	9.84	16.67
1560	72.9	9.43	22.61
1760	81.2	10.66	29.11
2040	91.0	12.30	38.03
2360	109.0	15.58	51.75
2800	125.6	18.45	69.17
3280	159.4	24.60	103.39
3840	162.4	26.24	118.31
4360	150.4	26.24	123.53
4800	138.3	25.01	125.89
5200	129.3	23.78	127.47
5600	118.8	22.14	125.50
5920	112.8	20.91	127.28
6200	107.5	20.09	126.39
6440	104.5	19.27	127.72
Code:
Group B:	'118
RPM	Temperature	Load	Absolute Pres.
/min	°C	%	mbar
1280	62.0	0.0	990.0
1240	63.0	0.0	990.0
1360	60.0	95.3	1010.0
1600	53.0	95.3	1160.0
1880	48.0	95.3	1290.0
2160	45.0	95.3	1440.0
2480	42.0	52.9	1680.0
2960	41.0	47.8	2030.0
3480	39.0	32.2	2420.0
4000	39.0	1.2	2310.0
4520	39.0	1.2	2070.0
4920	40.0	4.3	1970.0
5320	41.0	62.0	1830.0
5680	42.0	65.5	1700.0
6000	43.0	68.2	1610.0
6280	44.0	71.8	1560.0
Code:
Group A:	'032
Lambda	Lambda
3.9	12.5
L.R.C.
234
I know about the maf phil... but i find very weird the WG duty
Code:
1.2??? what could it be??
L.R.C.
234
UPDATE
replaced MAF, changed the IK22 with F5DPOR and cleaned my (stock) N75
only prob is after i changed the maf with the new one the TC light was coming on when i was trying full trhottle runs....
DTC: Maf signal too high
i erase the DTC while i was driving and since then no prob (until now)
my maf now shows 154.58g/s @ 5040 with no CF and O2 voltage is 0.885 with 3rd gear
L.R.C.
234
Looks good to me. Does the MAF signal too high still come up since clearing the codes?
Yes phil.... when i was coming home the TC light came up... (@4th gear)
what could be wrong???
