Boost issue with Vagcom Logs Help!!
jayjaycupra1.8t
93
Fitted botht the 008 and the n75 and I think were back to normal :)
Fitted the 008 first and it was better. Then fitted the n75 after and it was better again. Think I had a comination of the two.
I havent done any logs or had a proper test in it.....it was really wet so couldn't get the power down
Wheel spinning in forth gear in the wet a good indication that I have got my power back :) got a bit of driving to do for work tomorrow so ill have a prooer test and hopefully itll be dry.
I think I have shocked the ecu a little cause im getting a few pops and bangs etc. Will reset the ecu this weekend and probably give it a service too.
thank you all for your help!!!!!!!.
jayjaycupra1.8t
93
Drove around alot today....its warm and dry.
Although it is alot better....the intial kick is still no there
gonna reset the ecu now and then see what happens......
jayjaycupra1.8t
93
Hahahaha yes they are bad tyres.
BCT S800 thetre ok in the dry but awful in the wet.
Needed a set of four at the time so bought cheap ones.....174 for all four. Wont be buying them again though
225tt
My car makes this "hoot" noise on part throttle. Did changing the DV stop this or do you still get the noise?
