Hybrid K04 Turbo Discussion
wild willy
2,323
Wales
Just thought id share progress.
I've tweaked another 1mm and i'm getting there slowly. What i've also seen is that she's spooling as early as stock now where as before it was quite laggy.
I'm also surprised to see the intercooled air reaching 39 degrees, for ref outside air was 17degs. The PA intercooler should help here.
335.25 2800 24 95.3 1360
335.55 2760 24 95.3 1530
335.86 2880 24 95.3 1750
4th 336.16 2960 25 95.3 1980
336.46 3080 25 95.3 2270
336.76 3200 26 83.5 2530
337.06 3360 26 87.8 2540
337.47 3560 26 88.2 2540
337.77 3720 26 87.8 2540
338.07 3880 27 87.5 2540
338.37 4000 27 87.8 2540
338.67 4120 27 87.5 2540
338.97 4280 28 87.8 2540
339.28 4400 29 87.5 2540
339.58 4520 30 87.1 2540
339.98 4680 30 85.1 2510
340.29 4800 31 86.7 2430
340.68 4880 31 95.3 1710
340.99 4800 31 0 1750
341.29 4840 30 0 1310
341.59 4800 30 0 1180
341.89 4760 30 0 1110
342.19 4800 30 95.3 980
342.49 4760 30 95.3 1270
342.81 4840 31 95.3 1930
343.2 4960 32 95.3 2380
343.5 5040 32 95.3 2290
343.8 5160 33 95.3 2320
344.1 5240 33 95.3 2280
344.51 5400 33 95.3 2240
344.81 5480 34 95.3 2250
345.11 5560 34 95.3 2180
345.41 5640 35 95.3 2200
345.71 5760 36 95.3 2200
346.01 5800 36 95.3 2170
346.33 5920 37 95.3 2130
346.62 5960 38 95.3 2140
346.93 6040 39 95.3 2120
347.22 6120 39 95.3 2120
347.52 6200 39 95.3 2060
347.82 6280 39 95.3 2110
348.13 6360 40 95.3 2110
Softly softly catch a monkey. ;)
Mitchy
TTRS
Oct 12, 2004
2,310
Getting there mate, your keeping over 1.54bar boost for well over 1000rpm mid range (3360-4520 at very least)
How much over 1.54bar though? You got a gauge? Is it 1.8bar at 3360 dropping to 1.54 bar at 4520?
Think mines holds 1.54+ (limit of map sensor) from 3200-4700.
1.1 bar at 6000+ is ok, only really 0.15bar behind. FMIC might help that out.
wild willy
2,323
Wales
I think i need to plumb a decent dash mount boost gague in to measure how high this spike is, any recomendations. Yep i'm hoping the fmic will benefit the set up. The car feels very strong now and i'm happy that i have at least equalled the same boost pressures as my stock set up.
YerMother
comes and goes
Sep 22, 2004
1,461
East Midlands Drives: Scirocco GT
Getting there carl! I have done some logging this morning think will post some up later. Looks like the Wastegate is still letting go around 5500 prm as the wastgate duty cycle jumps from 85% to max!
39'C sounds about right Carl. FMIC will not reduce it by much! I'll post my block 118 to compare IATs.
YerMother
comes and goes
Sep 22, 2004
1,461
166.64 3000 32 95.3 1410
167.14 3160 32 95.3 1860
167.54 3320 33 88.2 2370
167.94 3520 33 84.7 2540
168.34 3680 33 84.7 2540
168.75 3880 33 84.3 2540
169.25 4120 33 84.7 2540
169.65 4320 33 85.5 2540
170.16 4520 34 86.3 2540
170.66 4720 34 85.1 2540
171.06 4880 35 86.7 2510
171.57 5080 36 88.5 2490
172.07 5240 36 94.3 2430
172.47 5360 37 95.3 2400
172.87 5480 37 95.3 2390
173.28 5640 38 95.3 2330
173.68 5720 39 95.3 2260
174.08 5840 39 95.3 2240
174.48 5960 39 95.3 2220
174.88 6080 39 95.3 2230
175.28 6160 39 95.3 2250
175.68 6280 40 95.3 2260
176.1 6360 41 95.3 2240
176.59 6440 42 95.3 2220
177.01 6560 42 95.3 2220
177.41 6640 43 95.3 2210
177.81 6720 44 95.3 2190
Here is 118 i logged the other day!
wild willy
2,323
Wales
Looking good Sie, Thats holding boost well at the limiter. Must be pulling very strong.
I´ll tweak more on the weekend hopefully.
You were right about the intake temps.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Is that a standard APR Stage 2 "boost profile" though? I know what I'm trying to describe (but not sure if it's called "boost profile" - the onset of boost/N75 duty seems quite low from 3300-5000 rpm where it used to spike like a bieatch.
Almost like it could make more boost, if top end didn't suffer...
YerMother
comes and goes
Sep 22, 2004
1,461
I didn't start the run untill 3k but it still spikes around 1.8BAR before it comes back to 1.5 obviously you can't see that on VAG-COM
It will boost more low down if the N75 allowed it but you can see it stays around 85%
SeatLeon20VT4
Seat Leon Topsport 20VT 4
May 28, 2004
73
Bergen Norway
Question about the actuator
My Turbodynamics turbo blew after about 10k. This was the reply from Turbodynamics when I tried to get this on warranty:
"The preload on the actuator is set from the
manufacturers specifications and re-set to factory settings when we build the
unit and under no circumstances should be changed"
Is this correct? And also, the claimed that even thoug my boost gauge showed 1,4bar of boost the turbo pruduced much higher figures due to the tampering with the actuator... Is this possible?!
YerMother
comes and goes
Sep 22, 2004
1,461
The things is with using a compressor heavy turbo is that the back pressure on the turbo side increases so if you use the factory preset value for the wastegate tensioner then the wastegate will blow open. Even with the turbines clipped back slightly on our hybrids the back pressure is still enough to blow open the wastegate.
If your boost gauge is showing 1.4 bar then thats the value of boost. Whether there is any left in the turbo depends.
SeatLeon20VT4
May 28, 2004
73
Bergen Norway
Actuator
So to get more boos I need to tighten the preload to the actuator? I read that 2-3mm should be enough.
Will this prevent the WG to blow open?
YerMother
comes and goes
Sep 22, 2004
1,461
The question is how can you be sure yours is blowing open. After all its a different hybrid!
We only realised that ours were because certain people couldn't reach the level of boost being achieved by others with the same turbo!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
one way to find out, but at your risk
you would expect to see a creep in N75 duty cycle when it started to push open I would have thought
SeatLeon20VT4
May 28, 2004
73
Bergen Norway
Boost controller
I run a APEXI AVCR boost controller.
Regarding the WG, I had a similar turbo before, an had no problem with running higher boost levels. Should you se a drop in boost when the WG opens? Because the boost curve is stable up to 5500 rpm...
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
not so easy to view deviation then if using apexi..
if you were on stock n75 then you would see a step when actual boost dropped from wastegate opening, as ecu tries to continue to achieve the requested boost.
not possible on apexi. (I dont think)
What duty cycle are you running the Apexi at?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
90% is max on apexi tho is'nt it
If you cars mapped to request the same boost as you apexi is set to then yea, you can log it
