sometimes Bill i wonder if your a computer i cant make heads or tails of what you just said perhaps i have to read it a few times over
i was just thinking that!
What he's saying, Ben, is:
00100101110101001101010010110011110.
He's saying that vag-com only reports 1.55 bar becuase the ECU only sees 1.55 bar, because the MAP sensor is capped at 1.55 bar, because it outputs a max of 5v to represent 1.55 bar. MAP sensors have been tested at higher than 1.55 bar and have output higher than 5v, but the signal is ignored because about 1.55bar that particular sensor generates an unreliable sensor.
Also what he's saying, is that if you swap your 2.55bar sensor for a 3bar TDi sensor, the 3bar one will output (something like) 5v to represent 2bar boost, so the ECU will see this 5volts and read it as 1.55bar.
Hence, the code/map that you run has to be recalibrated to no that 5v = 3bar, not 2.55bar.
Would logging the duty cycle of these hybrid turbos determine whether there is more left in them and its just the loading thats needs adjusting to up the power output.
You're all stuck in the same boat as billy and I. You fit a turbo and then 2 days later think 'I should have gone bigger'. I've only done that 4 times.
Which i have done! Its maxed out at just over 1.2BAR
On the hybrid, tuning should be able to control the boost spike to something reasonable, and should be able to max the turbo out at higher rpm.
On a small port 1.2bar at the limiter is about 225g/s. The head won't flow much more at 1.5bar and will only get up to 245g/s ish. From what I have read, the turbo just isn't capable of shifting that much air. VF34 wont shift more than that either.
It looks like it wil give you a solid 20hp over the standard one. I don't know how much you people expect.
i think i get it now basically the MAP sensor wont read higher than 1.5bar due to a cap and the reason for this cap is becuase they are not reliable after this or give off false readings. Vag com only records to 1.5 bar becuase the ECU and MAP sensor only record to 1.5 bar.
I am also guessing that when you say 2.55bar sensor that includes 1 bar of atmos pressure, what i dont understand is the 5v bit is that 5 vaults or something else and why do diesels have higher pressure sensors
so when you get to that point Bill what then a new project or maintain the current one
But why do diesels have a higher sensor
I also don't understand why JBS with CC couldn't remove the spiking with the remapping.
At the red Line I assume.
