Hub Convertors...
Ibiza Cupra
If i was to get 5 stub hub convertors could i fit LCR Brakes straight on if i get all the nessacary parts??
Ibiza Cupra
i thought the LCR was 320mm.
Ididn't think Cupra R's ibizsa had bigger discs????
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
You can't fit 5 stud brakes with hub convertors
You need to change your hubs to 5 stud.
Ibiza Cupra
OK. Well i thought i'd ask!!! I keep on getting these really good ideas in my head!!!!! One will work out one day!!!!
Ibiza Cupra
Do you know how much????
am i looking at hundreds or thousands???
Ibiza Cupra
Ok, well this is probably gonna be the next mod. Sounds stupid but are they a lot better than standard???
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Leon ones are bigger by 21mm in diameter. Same size pistons in the calipers, same size pads etc.
Leons have a very flat offset so wheel clearance is more of an issue for spokes to caliper. 305x28 disk is more inset so less caliper clearance for wheel spokes is req'd. (38mm vs 50mm)
£740 gets you a 4x100, 305x28 Disk setup, or you can go to 330x28 size if 2-piece disks, and wheels to clear em (17" minimum)
