How to change leds in dash cluster [Pic HEAVY]
Moominboy
How many LEDs are we talking about? Just if ya know off the top of yer heads!
Good guide btw! :)
Fishy
1,080
Why when the original LED's are flush mounted have you then mounted them on there side when installing the new ones?
Fish
Dankhan
Hey man did you have to use the vag com on your car after words or was it just able to be plugged back in and go?
Phoenix27
RIP Project Blueshift
Jan 17, 2010
838
Great Yarmouth, Norfolk
Hey dude... thanks for the link to this thread... don't suppose you've got any free time to help me with this have you? I'm only in Norwich and could come to you if that would help. :) No pressure, would be handy to have someone who's done this already on hand. :)
Kali
201
Scotland, U.K.
Hey. I just got white LEDs for mine. Just did the two main clocks but the white LEDs are not really bright. Does anyone know the reason and solution to that? I thought of just installing more LEDs but would that work?
Grant26
52
good thread definitely going to be changing the LEDs on my ibiza dash
Dankhan
This thread was a great in helping me change mine to blue... Just to say thanks :D
Dankhan
Also... I've noticed that my fuel indicator doesn't see to be right, the LCD one that is but every other control on the LCD screens seems to be working.. Any ideas or same happen to any of you?
supersticky
1,014
46
taunton somerset
Hey guys could anyone help! Does anyone know if these leds work like Christmas lights take one out and the others don't work as I've replaced these two, disconnected the other ones ready for being replaced but when I tested them there's no voltage??
The original full set
The two I've replaced and others two disconnected
Please help as I have work at 19:00 :':)'(
Dankhan
Hi mate. I recently replaced mine. Had the same problem a few times with the radio. They are connected to each other in some way. Make sure none of the solder is touching from positive and negative. I just kept replacing until they worked. Best to remove all old solder before putting any new solder on
supersticky
1,014
46
taunton somerset
Yeah I'm completely lost now, I think my soldering iron is burning the leds out when connecting them
