I fitted my 6k today and they seam to light up to the right more than normal do they need aligning. Is it easy to knock the lights out while doing it?
Thanks I will have a look tomorrow to check they are in right. How much should I pay for adjustment???
Hi,
Thanks for the heads-up on the HID's. I'm still unsure which kit (4, 6, 8 or 10) to fit?
I also wanted to know how long the lamps last and does it loose brightness if they're on for hours, as now we're coming into winter and my commute home from work can sometimes take over 4-5 hours, I don't want there to be any fade.
Any advise would be appreciated
Skimpywan
Thanks for that. I am not TOO fussed about the blue effect (not the rozzers the effect of the lamps) I just want superere visibility. So, would you go for 6 or 8 and is there any fade when they're on for hours of switching between main and head lights (as I never drive with side lights only)?
