Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
recently my var has been runing a bit rough on idle does not stick at 750rpm keep going up the 850rpm then coming down, now it seems that it isnt as quick before? serviced it 200 miles ago put ngk platinum plugs in it. possible coil pack? any help would be appreicated. thanks
could be your MAF. Try unplugging it to see what difference it makes. check its not dirty and the wiring is ok. MAFs can become less sensitive over time but not necessarily broken.
not got any pics but its a sensor sticking out of the induction pipe between the air filter and the engine. should be easy access. do a google search for maf sensor replacement on a leon or golf and there will probably be a thread somewhere that can help.
