Hi
I'm hoping someone out there can help. I'm having a pit of a nightmare programming the remote on a new key that I've purchased for my car. I've tried the manual method numerous times, but to no avail.
After a bit of digging, I was advised to try pairing the key through VAG-com. (http://www.ross-tech.com/vag-com/cars/vw-remote-matching.html) A very kind fellow forum member who has VAG-com helped me out and popped round... but we were still having no joy.
Basically she got as far as the computer showing how many keys were currently stored (1). She then entered the new total number of keys (2) in the 'new value' box and pressed 'test' - however it refused to update, and continued to show '1' in the test value... as such we didn't get much further!
Does anyone have any ides what could be wrong? Just FYI she also ran a diagnostic, and found a handfull of fault codes:
Address 01 -------------------------------------------------------
Controller: 06A 906 032 DE
Component: 1.8L R4/5VT 0001
Coding: 11510
Shop #: WSC 12851
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001
0 Faults Found:
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 901 D
Component: S5-KOMBIINSTR. VDO V03
Coding: 05424
Shop #: WSC 06441
IMMO-IDENTNR: SEZ7Z0A1063444
2 Faults Found:
01176 - Key
07-10 - Signal to Low - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
1 Faults Found:
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 8N Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 06441
2 Faults Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00942 - Exterior Mirror Retract Motor: Passenger Side (V122)
35-00 - -
Could these be causing some sort of conflict with the remote programming? Also out of interest, do these fault codes look particularly serious? The car seems to be running fine, and everything seems to work...
Many thanks in advance!
Coding: 11510
Shop #: WSC 12851
2 Faults Found:
Coding: 0022017
Shop #: WSC 00001
0 Faults Found:
Controller:
Coding: 05424
Shop #: WSC 06441
2 Faults Found:
01176 - Key
Coding: 00006
Shop #: WSC 06441
1 Faults Found:
Coding: 04097
Shop #: WSC 06441
2 Faults Found:
35-00 - -
35-00 - -
