Heat spots on discs
hadz
286
West Sussex
i was doing bout 80 last night and was coming to a roundabout so did dum fairly hard braking and got a really bad noise coming from the passenger front wheel! i took it to the garage today and they think its the disc thats the problem, they think that there are heat spots on the disc where it has overheated!
any1 else had the same problem?
had
flashbsd
you mean you had brake fade?
I had all of my discs/pads replaced with slightly uprated ones due to the same problem, you get a droning sound under hard braking, and struggle to stop.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
hot spots as in pad material stuck to disk.. more than likely.
hot brakes make noise.. simple as.
hadz
286
West Sussex
yeah thats it like a strange juddering type noise if that makes sense. i have just been quoted 177 for new pads and disc fitted! is that bout right?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
std ibiza disks and pads?
goign for std again or somethign which is a bit more durable?
ATE power disks of Stu @ ~£39 each plus some performance pads like ds2500's @ ~£68+vat and some good fluid like motul RBF600 to cope with hot temps as an option too..
the hot spots will rub off in time.. but can lead to judder.
flashbsd
got powerdiscs here, cant fault them :thumbup:
They will be cheaper than 39 i got all 4 and all 4 pads for 100 squid.
SWANSWAY CUPRA Dealership
