gtrs eliminator?
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
phil to get this cleared up!!! i think the pump was on the return line!!! surely the supply is the round tube one as this goes to bottom of fpr goes through this to the box section of the fuel rail to the injecters any fuel that is not used is returned via at the end of the box section!!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
Nov 2, 2004
9,335
South Wales
So if he doesnt have a wide band yet, how else will he see if its not running off the mark?
031 only gives you long term fuel trims, not on the fly fuelling info.
They get reset to 0 every time you either do a TBA or clear codes, thats why i said check them at the end of a long run.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
how does it regulate the pressure if it does not go to the regulater first, if it was correct surely both pumps were supplying fuel straight to the injectors!!!
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
Im sure thats not right and 031 is on the fly.
This is a log from mine before it was finally mapped for the K04
Code:
Wednesday	7	November	2007
6K0 906 032 AA		1.8L 20VT EU3   G   0002
	Group A:	'031		Group B:	'115
		Voltage	Voltage		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME			TIME
Marker	STAMP	 V	 V	STAMP	 /min	 %	 mbar	 mbar
	155.03	0.785	0.805	155.33	2040	78.9	1860	1400
	155.93	0.805	0.825	156.23	2240	97.7	2400	1680
	156.83	0.83	0.85	157.13	2480	118	2360	2040
	157.73	0.815	0.835	158.03	2760	140.6	2350	2520
	158.64	0.805	0.81	158.93	3080	161.7	2330	2540
	159.53	0.795	0.81	159.83	3480	169.2	2280	2540
	160.44	0.795	0.805	160.74	3760	160.2	2270	2540
	161.33	0.825	0.845	161.63	4040	142.1	2270	2430
	162.23	0.82	0.85	162.53	4280	141.4	2240	2370
	163.13	0.83	0.845	163.43	4560	145.1	2210	2380
	164.03	0.825	0.855	164.33	4760	132.3	2180	2200
	164.93	0.82	0.85	165.23	4960	132.3	2170	2190
	165.83	0.82	0.855	166.13	5160	132.3	2190	2190
	166.73	0.81	0.86	167.03	5360	132.3	2210	2210
	167.63	0.82	0.86	167.93	5560	131.6	2230	2210
	168.53	0.815	0.855	168.83	5760	129.3	2240	2250
	169.43	0.81	0.855	169.73	5920	131.6	2260	2270
	170.33	0.795	0.845	170.63	6040	130.8	2280	2250
	171.23	0.8	0.835	171.53	6240	128.6	2280	2280
	172.13	0.785	0.84	172.43	6320	127.8	2290	2290
	173.03	0.79	0.83	173.33	6480	126.3	2290	2280
	173.93	0.79	0.84	174.23	6560	124.8	2290	2280
	174.83	0.78	0.82	175.13	6960	33.8	1010	2390
Showing the fueling in the second coloum
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
right went for a little blast today car feels alot smoother than normal and idle is not as lumpy will do some more logs 2morrow with ian, dave is there any perticular blocks you want doing with new plugs!!!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
to recap... you know there's issues - so you've gone out & given it some stick? Then driven it for 2hrs?
you need certifying.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
well as ive said this is my only car and things need to be done, were did i say ive given it stick the only times ive been boosting it past 0 bar is on the logging!!! blast just means a drive sorry!!, but what does the white eletrode mean does that mean the timing is to advanced or its running lean???
