Dont bother logging 031, but its a good idea to see what the values are after a run.
So if he doesnt have a wide band yet, how else will he see if its not running off the mark?
031 only gives you long term fuel trims, not on the fly fuelling info.
They get reset to 0 every time you either do a TBA or clear codes, thats why i said check them at the end of a long run.
Wednesday 7 November 2007
6K0 906 032 AA 1.8L 20VT EU3 G 0002
Group A: '031 Group B: '115
Voltage Voltage RPM Load Absolute Pres. Absolute Pres.
TIME TIME
Marker STAMP V V STAMP /min % mbar mbar
155.03 0.785 0.805 155.33 2040 78.9 1860 1400
155.93 0.805 0.825 156.23 2240 97.7 2400 1680
156.83 0.83 0.85 157.13 2480 118 2360 2040
157.73 0.815 0.835 158.03 2760 140.6 2350 2520
158.64 0.805 0.81 158.93 3080 161.7 2330 2540
159.53 0.795 0.81 159.83 3480 169.2 2280 2540
160.44 0.795 0.805 160.74 3760 160.2 2270 2540
161.33 0.825 0.845 161.63 4040 142.1 2270 2430
162.23 0.82 0.85 162.53 4280 141.4 2240 2370
163.13 0.83 0.845 163.43 4560 145.1 2210 2380
164.03 0.825 0.855 164.33 4760 132.3 2180 2200
164.93 0.82 0.85 165.23 4960 132.3 2170 2190
165.83 0.82 0.855 166.13 5160 132.3 2190 2190
166.73 0.81 0.86 167.03 5360 132.3 2210 2210
167.63 0.82 0.86 167.93 5560 131.6 2230 2210
168.53 0.815 0.855 168.83 5760 129.3 2240 2250
169.43 0.81 0.855 169.73 5920 131.6 2260 2270
170.33 0.795 0.845 170.63 6040 130.8 2280 2250
171.23 0.8 0.835 171.53 6240 128.6 2280 2280
172.13 0.785 0.84 172.43 6320 127.8 2290 2290
173.03 0.79 0.83 173.33 6480 126.3 2290 2280
173.93 0.79 0.84 174.23 6560 124.8 2290 2280
174.83 0.78 0.82 175.13 6960 33.8 1010 2390
how does it regulate the pressure if it does not go to the regulater first, if it was correct surely both pumps were supplying fuel straight to the injectors!!!
why are you still driving this car?
