GT3071R ibiza build thread
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
bill have you seen the stainless exhaust housing you can get for the garrett gt range?
yea, they look lovely quality investment castings.
were'nt around when I bought mine else I would probably have gone for one... however, the inlet to them is 50mm ID which is too small, and smaller than my IHI style FP was (52mm) for my setup
I have'nt seen specs for this dimension other than from a couple of guys who have got them for their GT30 based setups, once of whome is likely to get a welded on stub out of the Tial housing to an external 44mm vbanded tial wastegate, that would be a compact way of doing things for sure.
yummmmm :drool:
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
its all to do with the fittings, I think most are flanged connections
The v band ones seem to be 'special' ones, or if you have enough money any turbo could have it
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
no gasket on vbands, so one less gasket to fail. allows rotation for alignment etc. simple one bolt clamping also.
{edit - and its much lighter}
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
right.
the fuel guage problem...
ive taken the pump out and checked it over. all looks good. on the s3 pump you need to solder 2 wires together from the 2nd fuel level sender. i checked continuity on that and is fine.
i then connected the pump back up but had it in my hands rather than in the tank. i had the level float set as if the tank was empty....gauge reads half a tank!?
i then lift the float as if tank is full....gauge drops to empty :S
does this sound like the level sender is faulty?
the pump is less than a year old :(
h17och
Sep 1, 2005
3,504
Dunstabubble
its a multi plug so you cant get it wrong. lol
but on the internal wires on the pump that go to the sender, i swaped them round but it didnt work still :(
h17och
Sep 1, 2005
3,504
Dunstabubble
if it was back to front i guess it would read full tank when float is low and empty when level is high. but it wont go above half :S
