right.
the fuel guage
problem...
ive taken the pump out and checked it over. all looks good. on the s3 pump you need to solder 2 wires together from the 2nd fuel level sender. i checked continuity on that and is fine.
i then connected the pump back up but had it in my hands rather than in the tank. i had the level float set as if the tank was empty....gauge reads half a tank!?
i then lift the float as if tank is full....gauge drops to empty :S
does this sound like the level sender is faulty?
the pump is less than a year old
