Thanks for all the comments lads, really appreciate them all
I haven't been on here for a long time..... family / work / life but most of all money is all getting in the way, and to be honest i've had to let the car take the back seat (pardon the pun)
Being broke really does play havoc with this type of project.... that and the fact me and the missus are expecting another addition to the family next March
In the few short trips into the garage i've had over the months i've been trying to complete stuff without spending money..... this of course doesn't keep you very interested in the project as i've been jumping from one job to another when i realise i need to buy parts / materials to finish.
I have been taking pics along the way, none of which are very interesting but in the interest of keeping the thread alive i thought i best put them all together.
I tried to work out some milestones to meet to keep me going along the way.
First off i wanted to try and get the engine bay wiring finished off, so set away tidying / recovering / re-routing the wiring loom. As the turbo has a big ass 4" inlet i wanted to run the pipe to the air filter behind the headlight into the void in front of the from wheel behind the side grill of the bumper.
To do this i needed to reroute all the wiring for the fans as it normally sits in a plastic tray which takes up a lot of space -
I removed the tray and tidied it all up and recovered with new loom cover -
Once i finished off the engine bay i decided that due to the expense of the materials i'll leave building the exhaust for now..... and moved onto another free job, putting the front end of the car together -
I fitted the wings / bonnet etc -
I had to source some M8 to M6 captive nuts as the bonnet had the wrong size inserts in when it was made.
As its a fibreglass bonnet there is no means of locking the bonnet using the standard locking mechanism, so i bought these a long time ago.... dusty packet -
Deciding where to put them was quite difficult, they are flat so really need to go on a flatfish surface of the bonnet..... i hate to see them mounted on a rounded surface and you can see one end sticking up
After quite a bit of nervous measuring i had the position sorted -
Then using a dremmel proceeded to cut out the holes....which then promptly gave up the ghost half way through AGAIN (thats 4 dremmels this project has killed !!!!)
After a quick trip to Argos i had replacement sorted and cut everything out.
The best place for the holes was partly into the strengthening webs of the bonnet, so i carefully cut out recesses and had to grind the surface level.
Holey sheet -
All Done -
Really happy with the finish and the look..... because racecar
I'll hopefully update again tomorrow night, plenty more to come including outdoory shots !!!
Thanks again for all the comments and support.
Graham.
Holey sheet -
All Done -
Graham.
