i assume IE have tested the "ribs" down the sides of the intake chamber and there for a reason, to disturb the air flow about each inlet trumpet opening![]()
Looks more like access to do the bolts up I think
Looks very good Graham.
Ithe wheels
Loving the progress graham! still going with white for the inside?![]()
To be fair Phil , both you & Tim know exactly why there are delays and the order was not complete as we kept adding bits to it.
I know you mean well but others reading this would think I hold there payment as ransom without shipping parts. We do not transfer funds from our paypal account until orders are 100% completed and shipped.
Graham, SEM manifolds are now in stock.
Integrated Engineering have just brought out a new inlet manifold...
Looks quite good and can be swapped to be fed from the drivers side which may suit you and your turbo position better...
Loving your work on this... most people would have just bought an S3 or something but fair play to you dude... love the engineering gone into this
<tuffty/>
Good shout Paul
Graham have to really commend you on this project the quality of work and the effort you have gone to is phenomenal and I'm sure this car will destroy 99.99% of the cars you ever put it up against
I've been following this thread closely for a long time and will do for ever more![]()
Started the mammoth task of removing the sound deadening, of this i used a scraper and a blow lamp to heat it up... feeling quite happy i then removed the cross piece that forms the front seat mount by drilling out the spot welds -
Used a bit of panel wipe to clean the glue / remains off -
I then thought i would remove the standard rear seat runners as i'll be using Bucket Seats with side mounts....... well i wish i hadn't bothered - the material is about 3mm thick and drilling out the spot welds took a life time - drilling and grinding for about 2 hours and the inside one still isn't out![]()
Painful job isn't it!! Weld in bars looks and feels so much more secure though. Looking good.
Mate, you are a HERO. If Carlsburg built car's they'd get you to build them.
Spent my Sunday afternoon reading this post from start to finish. Looking foward to seeing vids of this beast.
And all done on your drive way. AMAZING
and you took the time to write it up too, I feel as if I've known you for years.
Well done that man!!!!!!!!![]()
excellent work. sound proofing is a pain in the arse!!
having reread this thread there is only one flaw i can find....the gearbox needs a good clean!!! apart from that as everyone else has said a million times...excellent stuff!
Just read this from the start, what a truly awesome project! A true example of excellent engineering and a real life dream for any modifier! Hope it all goes to plan because this leon will become ****ography to all of us leon fans!!
Matt black would give it a mean look, which would look awesome, but I personally would love to see it finished in gloss black purely because when polished and buffed up it would look stunning!!! Looking forward to any updates, good luck with the rest of the build![]()
The EVO III is for the "larger gent" i'm slightly worried that it won't fit but hopefully it'll be fine and not foul on the cage.
I will get another seat eventually when funds allow but this will let me move the project along a bit.
I'll update again when it comes with some more piccys
The sealant under the car does catch fiire when you weld it.
Get an assisstant (in my case, it was me) and have them squirt water from a trigger bottle onto the weld area, from under the car, to keep the fire down.
Works well. You'll want to do it when you weld in the seat bars too.
Also regarding the seat I have an XL and a standard sized bucket seat, I'm a 30" waste because I'm a runt and the standard seat does not let me move at all, never mind when you do up the 6 points.
The XL is good for my mates with a larger waste. As for height the bars that Alex welded in for my seats are pretty much on the floor, you can just get your fingers underneath them. Basically enough room for the a battery relocation cable to squeeze underneath or similar.
Evo III outside measures are quite small. It fit almost everywhere, unlike Ergo. I hope that you are not very tall guy coz Evo III back rest is quite short (compared to evo II which is with tall back rest). (I work in company which sell Sparco etc. here in Finland)
Outside dimensions for Evo III
Max width 645mm (sorry about mm measurements) (at height point 600mm)
Max Height 875mm
Bottom width: min 440mm, max 570mm
Those are aprox. measurements by Sparco.
top build buddy
any updates?? its been a while
