Cage looks superb, Excellent work Graham!!!
The cage looks awesome Graham top work.
I had a dash flocked a couple of years back, if I remember rightly they cover it in glue, then electrically charge the dash causing the flock to react with the charge covering the whole thing and setting in the glue. It looked superb in my last car cost about £70 from memory!
It was brilliant!
what a weapon!
Ill be watching this one closely
Car is coming along really well Graham hats off to you as always. Couple of questions, how hard was it to remove the dash? And the top part of it can that be removed without taking the rest out?
I'm having some stuff flocked so think the dash would look good if it was done too if it comes out easily enough.
Cheers Adam
Thanks Mate, i'm very pleased with it still might add a cross brace between the sides of the main hoop.
when looking at it i thought about suggesting that but would it not foul the seats?
Graham, why don't you weld up the rear doors and make it a 3 door, whilst you're there would be pretty unique
Car looks pretty cool Graham, but just one question about the cage:
Why does there appear to be a butt joint in the front legs? I'm fairly sure M0rk mentioned it earlier. It looks like a nice and well designed cage, but that Butt weld just confuses me. it ruins an otherwise very well designed cage.
As it's in and done now, I understand you're not about to change it, but i'd seriously look into an additional sill - Roof memeber from the top of the windscreen joint down through the door bars to the base plate, like this:
You can see the bar I'm talking about in grey:
Adding in a diagonal in the main hoop will do wonders for rigidity too.
Do you have any cross bracing above the drivers head as well?
This car is going to be an absolute monster when it's done.
Lovely wheels too
great work!!!
sooo whats the next job? is this being painted now?
Looks like youve been very busy graham. Superb work!
oh also if your looking for a flocked dash i highly reccommend NEflock.co.uk. he has done a few pieces for me and the woek has always been 100% and quite cheap as well. would reccommend him 100000%
Are you using a baffled sump on this? (I make them now BTW)
To be fair Phil , both you & Tim know exactly why there are delays and the order was not complete as we kept adding bits to it.I feel your pain on that front Graham, Tim and i paid for our stuff from INA in Sept last year, I got the final instalment of mine in March, and Tim got the bulk of his last week and is still waiting on some parts.
Integrated Engineering have just brought out a new inlet manifold...
