Any more updates? I don't think I've ever checked someones thread so regularly!
Cheers mate, sorry no real update.... Other than i went back in the garage yesterday for a couple of hours and ripped the manifold back apart
I'm off to Ireland with work today, im away all week but when im back im off till the second week in January
I've decided to go with the Eurodyne Maestro 7 software, for those who don't know it uses the standard ecu but flashes a programmable software system on it so the user can adjust everything, remove options like SAI etc.
I will have to provide my spec list to Chris Tapp and he will write a map somewhere near what i need. He has a very good rep over on vwvortex with the U.S guys.
Doing a bit of forward planning for the spec list and i know my standard inlet manifold is not going to be ok at the flow levels im going to put through it. I did contemplate making a homebrew one with a bigger plenum and the agu runners but quite honestly i can't be arsed !!!!
So i will need to start fabbing up turbo pipes etc once i've finished the turbo manifold, So i thought i would go with the best manifold the SEM largeport with a 80mm opening, the only
problem is the throttle is on the wrong side so i will have to run the turbo outlet pipe behind the radiators and into the intercooler, no biggy really.
So due to the type of turbo i've got i'm gonna have to rev it hard, i have also got a price for some of Integrated Engineering IECVA1's Street / Strip camshafts, they are the daddies...gave over a 100bhp on there dyno motor over OEM so i think money well spent
Also getting a price for some 1000cc injectors and a dual 044 surge tank
So apart from all that the only thing to buy will be an intercooler, 75mm or 80mm throttle body and some big silly brakes..... some wheels...... Respray...... Or and some Buckets.
At least it'll be worth it
