Grahams81-Leon 4wd, Big Turbo - Back in the saddle :-)
grahams81
1,165
County Durham
Any more updates? I don't think I've ever checked someones thread so regularly!
Cheers mate, sorry no real update.... Other than i went back in the garage yesterday for a couple of hours and ripped the manifold back apart :cry:
I'm off to Ireland with work today, im away all week but when im back im off till the second week in January :D
I've decided to go with the Eurodyne Maestro 7 software, for those who don't know it uses the standard ecu but flashes a programmable software system on it so the user can adjust everything, remove options like SAI etc.
I will have to provide my spec list to Chris Tapp and he will write a map somewhere near what i need. He has a very good rep over on vwvortex with the U.S guys.
Doing a bit of forward planning for the spec list and i know my standard inlet manifold is not going to be ok at the flow levels im going to put through it. I did contemplate making a homebrew one with a bigger plenum and the agu runners but quite honestly i can't be arsed !!!!
So i will need to start fabbing up turbo pipes etc once i've finished the turbo manifold, So i thought i would go with the best manifold the SEM largeport with a 80mm opening, the only problem is the throttle is on the wrong side so i will have to run the turbo outlet pipe behind the radiators and into the intercooler, no biggy really.
So due to the type of turbo i've got i'm gonna have to rev it hard, i have also got a price for some of Integrated Engineering IECVA1's Street / Strip camshafts, they are the daddies...gave over a 100bhp on there dyno motor over OEM so i think money well spent :D
Also getting a price for some 1000cc injectors and a dual 044 surge tank :D
So apart from all that the only thing to buy will be an intercooler, 75mm or 80mm throttle body and some big silly brakes..... some wheels...... Respray...... Or and some Buckets.
At least it'll be worth it :D
Dec 19, 2006
673
This might be really silly but how much is the software? Got a couple of bits on my car that through up the eml so wouldn't mind getting those turned off.
8bit
3,401
Aberdeen
Wow. A lot of people call their RR a "build thread" but this really is a BUILD thread :) Can't wait to read more, awesome work so far.
grahams81
1,165
County Durham
Looking @ about $1000 for a driver and a file delivered so roughly £650
Cheers James, i managed to get mine for $750, quite happy with that as i wan't to do a bit of tinkering myself.... Of course after some serious research.
Cheers mate, really appreciate it.... Although i'm gonna just buy an inlet manifold complete, hope you guys don't think any less of me :D
If i had a AC TIG welder that could do ally i would have made one but it would have been too much hassle to have it welded up.
Agreed, strapping a couple of prefabs onto a car is not building
Needs submitting to http://www.build-threads.com/ once it nears completion.
Cheers M0rk, i'll have a look on that website when i get a few mins spare..
Again thanks for all the messages of support guys, this forum is great :cheers:
grahams81
1,165
County Durham
So it appears i have dropped a bollock....
I did quite a bit of research before i bought the parts for the manifold, everybody i found making mani's were using 1.5" either schedule 10 or the thicker 40, so i made the decision to go with the schedule 10 1.5" 316 stainless weld butt fittings.
I just happened to be searching for pics of manifolds on the internet last night and had a look on the Full Race website (manifold / welding **** !!!)
They make several different manifolds for Evo's, they make a "response" manifold for those wanting quick spooling with instant power, this is basically by changing the header size from 1.5" down to 1.25" 37mm ID apparently well suited for those looking for power between 500-800whp
They also make a big runner version for drag race customers with heavily ported heads, cams and +35psi......
I did think my 1.5" pipe ID was quite a bit bigger than the exhaust outlet from the head.
So i did a bit more reasearch and i found a size on VWVortex, it said the Exhaust outlet from the head is 34.8mm.
So the ID of the Schedule 10 1.5" i have is 42.7mm, for those that can't do maths thats 7.9mm bigger than the port, thats a lot of volume to fill.....hhhmmm stupidly big turbo, really long manifold (24" long runners) and big pipes = slllllooooowww spool up.
The 1.25" sch10 pipe ID is 36.6mm this is a better size for the manifold and will dramatically reduce the volume of the headers and spool the turbo up faster, especially when my manifold is a long design. The smaller diameter will reduce the expansion of the hot gasses keeping them hotter and flowing faster.
I understand the standard manifold is bigger than the port, i.e stepped - most people say that step is to try and reduce the back flow of gases flowing back into the cylinder due to cam overlaps etc.
I would imagine that the step is of greater importance with a standard log style manifold that has very poor exhaust gas scavenging and is single scroll.
With the twin scroll design the exhaust gas scavenging will be much better, this means the exhaust gas is drawn or sucked out of the cylinder.
This is due to the 2 paired cylinders, as one energy pulse passes the merge point of the paired cylinder it creates a negative pressure behind it, that negative pressure pulls the gasses from the other cylinder.
This also leads to lower cylinder temps so det can be reduced.
After i did some more research i found a couple of guys on various sites who seemed to know there stuff, most said the difference in runner size can make a difference by 3-400rpm.
So after getting a turbo bigger than originally planned (laggier) i think i should go the extra mile and remake the manifold in 1.25" to try and spool it as fast as possible.
Plus if Full Race say there Evo Response manifolds are ok for upto 800 Wheel HP then it's gonna flow more than enough for me.
I'm gonna order a load of 1.25 Schedule 10 fittings and pipe so when i get back from Ireland i can start remaking the collector and manifold.
So i spent the best part of 4-5 days working on the manifold thats wasted but hey it was good practice..
Oh well you live and learn.
joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
Finish off the mani you've made and patent it for future, could make yourself a nice number :)
Anyway best of luck and you'll probably only have to make the new one once after all this practise.
Really enjoying the build Graham.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
^ Good call Joe!
Graham.. sorry to read of the setback here with the mani. I'm sure going at it again will be the right thing to do though, and with all the work put in so far, it makes sense to do it properly.
Cracking read as always bud.
grahams81
1,165
County Durham
Bad news matey :(
Yeh mate it kinda is.... just a waste of money and my time. :cry: :censored:
So i've just ordered all the 1.25" fittings from colglo.
Also just ordered another T4 divided turbo flange in 12mm stainless with M10 tapped holes, The one i have been working with was ordered off ebay and it came in 10mm stainless with drilled holes and there was't really enough space for nuts on the collector side.
I also ordered another head flange so when im finished the car i can maybe make another manifold and sell it to recoup some of the money off the fittings etc.
Also ordered a tight radius 3" stainless 90 bend, 2 long radius bends and a length of straight pipe to make the downpipe.
I love internet shopping :D
edit --- wow you guys type quick, cheers for the comments lads. Like they say practice makes perfect !!! i think i will be on version 5 of the mani when i get back.....
