Well i got a reply from John @ Treadstone, not good news on the 7670 front.....
But he offered me a EFR8374 Twin Scroll Internal Wastegate that he managed to get his hands on - so i've took it
All paid for so should be with me soon...yey
So its not a GT40 but it flows more
So its gonna be really mental, and i imagine it make take a while to spool, but hey its no daily driver.
The specs are as follows -
EFR 8374 is engineered to support big power levels yet spool fast enough for professional time attack teams. The 74mm Gamma-Ti turbine wheel is the optimal match for the 62.6mm inducer / 83mm exducer FMW compressor wheel and is capable of 79lb/min airflow and 45+psi boost. This is one of the most exciting turbos in the EFR lineup for the high-power addicts. This turbo has the largest EFR compressor housing and is ideal for use in single turbo applications for the
500-800hp range or as twin turbo applications >1400+hp. Ceramic Ball Bearing only, watercooling optional (recommended)
Compressor Specifications
■Compressor Type: Forged-Milled Wheel (FMW) Extended Tip
■Compressor Wheel OD (exducer): 83mm
■Compressor Wheel Inducer: 62.6mm
■Max Flow Rate: 79 lb/min
■Built-in BOV: All EFR compressor housings incorporate an integrated BOV.
■Compressor Housing Connections:
■Inlet: 4" Ported Shroud Hose Coupler
■Outlet: 2.5" Hose Coupler w/ integrated Vband option
Turbine Specifications
■Turbine Type: Low Inertia Gamma-Ti Turbine Wheel
■Turbine Wheel OD: 74mm
■Stainless Steel Investment cast Housing - The EFR 8374 turbine housing configuration:
■0.92 A/R T4 twinscroll (Internal WG)
■Turbine outlet: GT-Vband (aka small 3" vband) ~92mm OD for all EFR turbos
Features
■Dual Row Ceramic Ball Bearings - lowest friction and fastest spool/response, most extreme durability, built-in oil control orifice - (aka oil restrictor) **no restrictor can be used with EFR turbos
■Watercooled Center Section - watercooling is recommended, 14mm banjo bolts
■Double seals on both turbine and compressor end for extreme durability and resistance to any oil seepage
■Boost Control Solenoid Valve Integrated to Compressor Housing
■Integrated Speed Sensor mounting provisions
So i've got some serious work and research to do, there is a dyno graph of the Sierra Sierra Evo 2.2L time attack car (fitted with a 8374 with larger twin scroll housing) and it looks like its coming on boost from 4000rpm full by 5000rpm. Hopefully on the smaller a/r turbine housing it will spin up a bit sooner.
Dyno of Sierra Evo -
So you guys wanted GT40 - this bad boy flows more one !!!!
Couple of "borrowed" photo's of 8374's -
What do you guys think eh ???
