Gearbox
DUB BOY
119
London
Right i picked up my first leon dannyboi's old one, driving alond and the gearbox seems to be very stiff, also i struggle to find reverse and some time 3rd and 1st, what could this be? Do i need to put the clucth to the floor or not, is it a hydraulic clutch? Any ideas?
Thanks Sam
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
You need to have the clutch pedal all the way to the floor before you change gear, yes.
why would it be any other way?
could be gear box linkages too
RedBeard
Possible syncro issues? Does it crunch when engaging or just stiff? Better when warm? Checked transmission fluid all ok?
DUB BOY
119
London
it doesnt do it all the time only sometimes but you have to smack it in reverse, was thinking gearbox fluid may need doing or something like that. I dont think its got a quick shift, ill get some pics up later of the selector so someone can confirm this. If its the cables is this a cheap fix?
Thanks for the help guys
Sam
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Sam
I have the uprated INA Engineering ones that were about £120 from memory.
Pictures would help
DUB BOY
119
London
been out in it today and its got all gears and running fine, must of just been me being used to a sloppy mk1 golf 4 speed box lol
godber225r
T15 PJG
Sep 6, 2008
893
Whiteley, Hampshire
The gears are good on these cars you only have to pull and push the lever to put it in gear and with hardly any effort. you only have to push the lever over when changing from 4th to 5th.
If you have a crunch in any gears thats defo the oil level in there. top up or change the gear oil. i had a slight crunch from 2nd to 3rd i changed the oil and it never happened again the gearbox is lovely. I changed it with the standard vw gear oil from the dealers.
Quick shift there would be hardly any movement in the gear lever when going through the gears.
DUB BOY
119
London
cheers mate theres no crunching at all when changing gears, its been fine today. Dont think it has a quick shift kit in it. how hard is it to change the gearbox oil? or am i better of taking it amd's and getting a full service done?
godber225r
T15 PJG
Sep 6, 2008
893
Whiteley, Hampshire
Its easy to change the gear oil just a tamperproof spline socket you need.
Just looked in the draper catalogue and theres one in there for these cars for 6 quid.
You could get a full service done but i dont think the gear oil is included you will have to tell them that you want that doing aswell.
