Front Mount Intercooler
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
Mine is on :) what a ball ache that was. My old coupler from the Golf fits perfectly. Guys with the type E, I'm guessing you reused the seal from the boost pipe you removed... did it fit nicely? I tried the o ring from the S pipe I removed and it wasn't a nice fit on the coupler at all (too big) so used the one from my Golf and it's perfect.
Apr 1, 2014
865
'up anley duck'
mines on. would of done it sooner but fitted the dreaded Rs4 valve as well.
yea i used the rubber seal from the oe pipe was a good fit.
865
'up anley duck'
its way bigger than the s3 cooler i had on previous.
the S3 intercooler measured 39.23mm i thought it was suppose to be 45mm?
anyway this one measured 59.48mm.
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Yeah its massive. I had to trim a fair bit of plastic all around to move the rad pack forward enough until until I was happy with the clearance for the fans. Very tight fit. Found the Apr fitting guide very useful too, handy to refer to
Can't wait to start logging, hopefully tomorrow night :)
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
I think it might be slightly different but it's still a perfect fit, absolutely solid with no play at all. The original seal would have worked ok but was ever so slightly too large for the tdi coupling I'm using.
If the CM one fits with the original seal then go for that. Cheap and easy resolution (in the end :))
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Took mine for a blast this morning on the way to go karting and it's definitely a big improvement and IATS are definitely lower. Only checked through Torque app, plan to do some logging shortly. RR would be good, might take it back to the RR I went to a few months back for another run at some point
DGF264
850
County Durham
Hoping to fit my type E and Josh's S bend pipe today..as I mangled my metal boost pipe a bit trying to 'whack' the china coupling in..I hope I haven't damaged it to the point where it's out of shape and just blows this type E coupling out..like it did the other day :( (it popped out the standard pipe on boost)
WeeG
3,407
Largs , Ayrshire
I was logging yesterday with the Revo stasis euro jet cooler with AC delete and 50/50 meth set up. Ambient temp was 16.5 degrees, on a 4th gear WOT run from 2000 rpm to red line IAT's were just 10 degrees! 6.5 below ambient
DGF264
850
County Durham
Lol ok! Well.. S bend pipe from Josh (which he got from darkside) appeared a little too big..so I've cut it down, a little at a time. Guess what.....
It's now no good as it's not long enough to go over cooler & coupler!! So I'm back to bloody square one!! :( :( had to re fit my bodged pipe again!! :(
Messaged china seller asking how much for just an S bend pipe. I know I've fu***d up and am a **** for shortening the pipe. So I don't need anyone else telling me lol :(
