forge DV
D.K
LCR 225
Oct 24, 2007
6,408
se london
Even if you put a Split-R on it wont be very loud, A remap and an open cone filter or a modded O/E airbox will help but they are still not very loud.
Stick with your 007 and do the above mods.
CupraR_Lad
515
Herefordshire
Ok I think i will go for the Green Cotton open airfilter first and see how it that changes it!will the green cotton increase inlet temps?
big eck
3,976
Falkirk, Scotland
I have the exact dump valve as you cupralad and just modded my original air box and the DV noise is much louder and very noticable from inside the car. Mine was silent to begin with.
Dec 6, 2008
612
Shropshire
so what way is the loudest way to fit the dv?
Wearing something like this while your fitting it will probably be quiet loud, defo wake the neighbours up :happy:
ryan106
87
From what I have read on here fitting it in reverse makes it louder I am going to do it to mine at the weekend hopefully so be interesting to see, believe its perfectly fine to do it like this.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
i found that a smoothed and drilled airbox is very similar in loudness to an open cone filter - certainly loud enough for people to comment when first in the car! the dv can be orientated either way, it is only a simple valve. When I reversed mine the woosh turned to a metallic chirp; i've since returned it to standard direction. The N249 bypass made my dv significantly louder; not sure why!
