Fitting K03s Turbo
Deleted member 9043
i went to the vw store to get the gaskets etc for k03s to fit,
they give me 3 tap-ends for the mani to the turbo?
i thougt there where 3 bolts to connect this?
or makes this no difference?
sparkus2
changing turbo with out ramp can be done its a bit of a pain but i managed it on my own had to remove manifold and just undone front pipe bolts which let it drop down out of way but undoing the front pipe bolts is a mission on its own as well as undoing water pipes from turbo and block took me 7hrs to do but worth it in my case.I built my own turbo ive got a ko4 off audi tt225hpmachined out original ex housing from ibiza to suit bigger shaft fan then had the inlet clam shell from tt basically cut and sut so could have original bend from ibiza clam shell on it so boost pie etc would locate back in original place infact when u look under bonnet it looks kike standard turbo apart from the samco 90 degree elbo coming of the front of.lets just say pulls like a train now just waiting to get another remap to take it to maximum performance.
Deleted member 9043
im now buisy with a k03s swap but on the wg actuator of the k03s i got only 1 vacuum pipe instead of 2?
kan i put a simple T piece or can i close one of the vacuum lines?
grtz
Shock_Xe
grtz
the one u dont have a feed for u simply block/bung
Mark@VAGWORX
SEat Regular
May 15, 2003
401
Nr Colchester, Essex
So, if i'm thinking along the right lines........Our K03 actuator has 2 ports rather than the conventional 1.
Presumably one vacuum goes to the N75, were does the other go?
Secondly, surely if the Mk3 Cupra is ment to run the 2 vacuum lines, aren't you going to be sending the wrong signals to the ECU?
Can you not take the 2 port actuator off the K03 and put it on the K03s?!? :confused:
Deleted member 9043
i believe the other one is placed between the n249 and another round metal thing i dont know
sparkus2
when i did mine i just blocked the second pipe ive been told its just a breather and no harm will come by a reliable vw and audi specialist that i no.
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
I removed my ko3 on monday and i used the wheel changing jack (which doesnt go very high) and then wedged a wheel ramp under the subframe!!! I could just squeeze under! Didnt take that long either!
Would a 2003 leon cupra (180bhp) have a ko3s?
Also can i run satge 1 revo with a ko3s? or do i need a custom map?
Cheers guys :D
HoocH
AlphaMale
347
Cardiff
Cheers guys :D
HoocH
The 150bhp is AUM with a KO3s and the 180bhp AUQ also with a KO3s.
THIS Thread might aid you.
Alpha
(gonna do a KO3s change soon)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
thermalp4 said:
I'll be taking mine to a professional outfit to get it fitted. If anything goes wrong then you'r in the S**T!
Ain't much better if you use a 'proffessional' outfit - you will just pay more in labour if stuff goes wrong.
thermalp4
253
South Wales
Valid point lads, but surely to do it properly your gonna need a ramp to get it high enough.
I could probably do it, especially if i see it being done once. Its just that its my only car so if i havent got the right tools to do it in the first place its kinda put me off.
How long a job is it really? And could you use axle stands? seriously.
AlphaMale
347
Cardiff
And half the time they are no more skilled than us :(
I'll be doing it myself as I can afford to spend all day on it and if push comes to shove and I can't use my car for 3/4 days I'll simply use my R6 :D
I have the right tools (all I needed while working in Audi) but a ramp/pit would be handy.
Alpha
