ok here is the vagcom report
VAG-COM Version: Release 311.2-N
Chassis Type: 6L -
Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 NJ
Component: 1,9l R4 EDC 0000SG 9810
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ8R022421 SEZ7Z0G3885709
1 Fault Found:
17568 - Manifold Temp Sensor (G72): Short to Ground
P1160 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AG
Component: MABS 8.0 front H05 0002
Coding: 0002238
Shop #: WSC 06402
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 00012
Shop #: WSC 04767
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 923 G
Component: KOMBIINSTRUMENT VDO V02
Coding: 00405
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00017
Shop #: WSC 04767
Address 56 -------------------------------------------------------
Controller: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
any ideas peps?
