Fitted Seat sport FMIC and PD160 intake and now warning lights up
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
hi guys and girls,
just fitted the seat sport fmic and PD160 intake and now my engine management light and tcs light have come up:(
any ideas??
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
where u get the SSFMIC Steve?
I so want to stick one on mine but funds are extinct at the mo lol...all in due time with remap to follow ;)
don't see what would trigger the engine management light if you just done simple replacement of parts...
st10587
Oct 4, 2007
3,669
Hindhead
i got it from sere motors on here and then the pipework kit from forge. total cost was £445.00
i cant see the intake or the FMIC has caused the fault. might try the old intake jsut to see if that makes a difference untill i can get my laptop working or get a fault code reader on it.
NickyJam
Mar 17, 2008
1,669
SW LONDON
the intake won't make a difference mate...been running the PD160 on mine from new (over 16 months now) and been fine, makes a slightly more whistley noise with it on
hmm...i should have got the used one that went into the for sale section earlier this year, but didn't want to spend the money at that time (lucky i didn't otherwise my holidays wouldn't have happened)
Dec 16, 2007
432
Gloucester/Cheltenham
the sensor on the intercooler been plugged back in? the one that goes in the SMIC (which would now be on the FMIC)
the PD160 intake shouldnt make any difference as far as i know.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Could be the MAF, I had the EML and TCL on when I had a dead MAF.
Without vag-com we can only guess though, Steve..
st10587
Oct 4, 2007
3,669
Hindhead
ok here is the vagcom report
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 NJ
Component: 1,9l R4 EDC 0000SG 9810
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ8R022421 SEZ7Z0G3885709
1 Fault Found:
17568 - Manifold Temp Sensor (G72): Short to Ground
P1160 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AG
Component: MABS 8.0 front H05 0002
Coding: 0002238
Shop #: WSC 06402
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 00012
Shop #: WSC 04767
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 923 G
Component: KOMBIINSTRUMENT VDO V02
Coding: 00405
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00017
Shop #: WSC 04767
Address 56 -------------------------------------------------------
Controller: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
any ideas peps?
st10587
Oct 4, 2007
3,669
Hindhead
any one know if the manifold temp sensor could have been effected byy the FMIC? i take it its not the sensor on the ic pipe?
