Fault Codes - Search this thread 1st
mtarifi
please help!!!!!!
please help me guys, i have installed a uni chip in my seat leon FR 2008 model with the 2.0tfsi engine. after installing the chip i got the check engine light and yesterday i did a dignaostic using the vag-com and got the following errors.
Saturday,24,November,2007,23:41:37
VAG-COM Version: Release 512.4-UD
Control Module Part Number: 1P0 907 115
Component and/or Version: 2.0l R4/4V TFSI 0040
Software Coding: Long Coding
Work Shop Code:
7 Faults Found:
012902 - Oxygen (Lambda) Sensor B1 S1: Internal Resistance Implausible
P3266 - 008 - Implausible Signal
000305 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 002 - Lower Limit Exceeded - Intermittent
004243 - Bank 1; Fuel Measuring System 2: Malfunction
P1093 - 008 - Implausible Signal - Intermittent
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction / Open Circuit
P0030 - 004 - No Signal/Communication - Intermittent
005634 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 002 - Lower Limit Exceeded
can anyone help me what to do. i have cleared the errors using the software and the check engine didnt come up again. so please instruct me what to do.
what does these errors mean and is there a place where it tells u which errors and what is causing it.
mtarifi
i havent installed any thing except the Uni Chip its a peggy chip for the ecu.
Sentinel
nice one with the fault codes great help! would be cool if there was some sort of level of urgency for each one. just a suggestion. once again thanks though great post MORK
Sentinel
hi there just bought a lcr, about two weeks ago, loving it but, now the engine management light lit up and got the codes checked out and they are as follows. ( eoi = error occurs intermittently and swg = short with ground)
17524 O2 heater circuit bank 1
17511 O2 heater circuit bank 1 capacity too low
17833 tank ventilation valve short with ground (swg) eoi
17525 02 heater circuit bank 1 swg eoi
17953 control valve boost pressure swg eoi
17938 camshaft adjustment swg
17697 valve turbo swg eoi
17863 exhuast gas trap sensor not a plausble signal eoi.
im no mechanic but im pretty sure this isnt right, because im new to this car can anyone shed some light as to what may be casuing them and how urgent they are. i have just bought it for 10,000 private so am a bit skint. just to mention the car has been remapped by jabba sport, bfore i bought it and the only thing i have done since owning it is fit an alarm which is quite a complicted one s with full closure and etc. i do have an aftermarket exhuast blue flame i think and a forge dump valve 007. much appreciated. am i ruining it if drive it. How much am i looking at to fix it .....i am gutted
lynda1985
just got these codes from the car can any1 help:
05697
00665
00257
many thanks lynda
CARL BRIGHTON
Chicken Choker
Jan 8, 2002
316
Gainsboro
hello, anyone help with these?
VAG-COM Version: Release 409.1-S
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 037 906 024 AP
Component: DIGIFANT 1.7 1729
4 Faults Found:
00525 - Oxygen Sensor (G39)
03-10 - No Signal - Intermittent
00524 - Shareware Version. To Decode all DTCs
03-10 - Please Register/Activate - Intermittent
17978 - Shareware Version. To Decode all DTCs
P1570 - 35-00 - Please Register/Activate
00518 - Throttle Position Sensor (G69)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Skipping Address 15-Airbags
Address 25: Immobilizer
Controller: 1H0 953 257 B
Component: IMMO VWZ3Z0S0285916 V00
Coding: 09600
Shop #: WSC 05811
No fault code found.
Slippery_Stu
72
Hi,
My traction control light comes on and stays on after approximately 15 mins of driving (NB. this is not due to the TCS button being pressed!), so I took the car to a mechanic friend who plugged it into his Snap-on handheld diagnostic machine which returned just the one error code:-
18265 P1857 Load Signal Error Message from Engine Contr.
What does this actually mean?? Has his handheld device not worked correctly or does this actually indicate/identify a specific faulty item?
Can anyone help?
Stuart
Ibiza FR TDi
daljomo
my wife, I WISH !!!!!!!!
Nov 26, 2004
70
barton on humber north linc`s
code ??????????
has anyone heardo f acode number 01423 as thats the one i get for my esp light being on im getting ful drive in dry weather but when its wet my wheels are slipping all over the place and carnt get no power down at all
mixupz
Just call me Rash-MIX
Oct 5, 2007
1,538
Dirty South East London
hi people id greatly appreciate it if someone could tell me what this fault code means.. my car went into crazy Hunting mode today, rough idling....had it VAGc'd and this came out
15556 _ (i glanced over the guys shoulder and it said something about too rich something like fuel systme) not sure
o also i got the 16514 code but looked on his thread and its the 02 sensor 1, im guessing thats the lambda probe 1 on the manifold..
I REALLY need guidance on this
MrNailer
81
just wanting to know what this code is plz mork
17057 - Shareware Version. To Decode all DTCs
P0673 - 35-10 - Please Register/Activate - Intermittent
thanks nailer
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
thanks nailer
17057/P0673/001651 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
Possible Symptoms
* No Pre-Glow Period
* Poor Cold Starting
Possible Causes
* Glow Plug Wiring faulty
* Glow Plug faulty
Possible Solutions
* Check Glow Plug Wiring
* Check Glow Plug
Special Notes
MrNailer
81
thanks alot m8my m8 had engine light on so i did vag com check once again thanks
Matt_FR
my 1.820vt has brought up p1200-recirculatibng valve for turbocharger- n249:mechanical malfunction
p0300 random multiple cylinder misfire detected
p0302 clylinder 2 misfire detected..
swapped no 2 dis coil to number 4 and will give it a run later to see if it brings up no4 code and if it is indeed a dis coil pack...
anybody got any ideas?
just started runniong like **** last night.. still pretty standard too.. standard boost etc...
