Fault Codes - Search this thread 1st
stu 157-330
80
West lothian
fault codes
Hi, having read the list i can hopefully go to seat and find out if the fault i've got can be sorted.. on my ibiza cupra tdi
18268- relating to a kickdown switch error, although the traction light came on..
Binksy
Leon Cupra
Nov 27, 2009
89
Norwich
I have this error code!
16486 P0102 Mass or Volume Air Flow Circ Low Input
Does this mean it just needs a new maf censor ?
magicoi
254
Lincolnshire
I have 17056 01/02
Is this a glow plug issue? Code is not listed on the first page. Dont have VAG COM but a VAG code reader.
BigSighZ400
my system was running too lean so i eliminated the possiblities in order of expense!
turns out it was the first one. fuel filter. there are two types for my mk2 leon 1.6
3 bar and 4 bar. i had the 3 fitted during a service unbeknownst to myself and the mech who had never seen two different sorts for the same car before. so i bought the more expensive 4 bar filter and bingo bango she's lit again!
problem solved!
Sio_08
What does fault code P2251 mean? i know its emissions? i think? as well will this be a cause of my fuel mpg has gone down to 28? Hope you can help.
Cheers!
Cupra_20vT
64
can anyone help me out i have a vw touareg and theses code on it and i cant find what is the problem.
Address 01: Engine
6 Faults Found:
004203 - Throttle Valve: Stuck or difficult to move
P106B - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 22
Mileage: 76659 km
Time Indication: 0
Date: 2011.04.14
Time: 10:23:22
Freeze Frame:
RPM: 1197 /min
Torque: 70.2 Nm
Voltage: 2.000 V
Duty Cycle: 75.8 %
Duty Cycle: 60.0 %
005785 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 77023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.27 V
Bin. Bits: 00001000
005687 - Powertrain Data Bus: Missing Message from Electric Load Controller
P1637 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 77023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.27 V
Bin. Bits: 11001000
005685 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 77023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.27 V
Bin. Bits: 11001000
P1637 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 77023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.27 V
Bin. Bits: 11001000
005712 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 77023 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 98.0
Voltage: 9.35 V
Temperature: 13.5°C
Address 03: ABS Brakes
2 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 6401
Count: 203
Count: 3
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 19
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:51:26
Freeze Frame:
Count: 0
Count: 6145
Count: 128
Count: 3
Address 05: Acc/Start Auth.
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
009 - Open or Short to Ground - Intermittent
Address 08: Auto HVAC
4 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
00445 - Loss of Refrigerant
000 - -
Freeze Frame:
Temperature: 83.0°C
RPM: 768 /min
Absolute Pres.: 6.0 bar
Load: 67.0 %
Temperature: 18.0°C
Temperature: 21.0°C
Load: 4.8 %
Temperature: 89.0°C
Freeze Frame:
Address 09: Cent. Elect.
4 Faults Found:
01314 - Engine Control Module
01315 - Transmission Control Module
01321 - Control Module for Airbags (J234)
Address 17: Instruments
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 4
Reset counter: 62
Mileage: 76659 km
Time Indication: 0
Date: 2011.04.14
Time: 10:18:06
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:06:28
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:51:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 10:02:30
Address 19: CAN Gateway
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 62
Mileage: 76659 km
Time Indication: 0
Date: 2011.04.14
Time: 10:18:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:06:28
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 10:02:30
Address 37: Navigation (J0506)
2 Faults Found:
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 3
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:53:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:51:57
Address 46: Central Conv.
Part No: 7L0 959 701 R
Component: Tuersteuergeraet FS 6302
Part No: 7L0 959 702 R
Component: Tuersteuergeraet BF 6302
Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
2 Faults Found:
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
012 - Electrical Fault in Circuit - Intermittent
Address 56: Radio (J0506)
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:53:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 09:51:57
Address 69: Trailer Labels: Redir Fail!
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 10:02:45
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 77023 km
Time Indication: 0
Date: 2011.04.18
Time: 10:02:45
End
NEDDER
P1296 Cooling system malfunction
17704 P1296 Cooling system malfunction
keep getting this code coming up ,,, could it be something to do with me removing my thermostat last week due to it be faulty ,, got told it would be ok to run without it ,,
mk 1 20vt turbo ;)
Richie_856
P0546 Sensor 1 for exhaust gas temperature bank1 01350. Any1 got any ideas its a 1.9tdi ecomotive..... help please......!!!!!!!!!!
seatturbopower
350
birmingham
mk 1 20vt turbo ;)
i got the same code coming up as well on one of my mates vag computers he hooked up to my car (1296)the stat was changed a few weeks ago also,got rid of the light and it came back on :confused: taken to the garage and then they said its the 02 sensor so ill be changing that and see if thats my problem.......
F1990
33
Mitcham Surrey
Hi, I have fault code of P1633 G185 Accelerator position sensor signal too low. This has only happened when I tried to fit my boost and oil pressure gauge yesterday. Im guessing I have messed a wire up when drilling through the spare grommet holes. But I dont even know where to start and what I am looking for? Theres like a million wires down there.
