engine wont start fault code 01314
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Have you tried swaping out the ecu from your mates car yet...???
shouldnt be too much hopefully from a scrappy if you need a new one...
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
You can code them using vag-com not sure how ive never done it but it is possible...
there proberly a guide on here some where maybe in the vag-com section...
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Very simple, alot eaiser than some people make out.
Install the new ECU in the car
[Select]
[17 - Instruments]
[Adaptation - 10]
Leave channel at "00"
[Read]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
[Exit]
Turn ignition OFF for 15 seconds. Start vehicle.
May 25, 2008
2,400
cambs
is there a crash sensor on these cars? Just a thought .pugs have them that stop the engine running/starting.
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
No inertia switch.
Mr Peach really needs to swap ECU with a mate or get a compatible spare off eBay as a good fault finding measure, but only after checking power and relevant relays as above.
