change the fuel pump relay! chances are if its turnign over, making a spark, and not fuel purging when you turn the ignition on, its the relay most likely!
right-o just mentioned it cause i did the exact same thing in one of my previous cars and it turned out to be the starter motor......bumped started fine
Mr Peach really needs to swap ECU with a mate or get a compatible spare off eBay as a good fault finding measure, but only after checking power and relevant relays as above.
