Right I have a 1.2 2003 ibiza which is undrivable.
The car will judder with no revs and will misfire when accelerating.
Ive had the coils replaced and the spark plugs replaced and had a new crankshaft sensor installed.
Then someone said it was the ecu so i sent that off to be repaired and tested but the test said that the ECU was in good working order so now im stuck.
Any idea's?
Its the AZQ model.
Many thanks.
Any idea's?
Its the AZQ model.
Many thanks.
