Engine Management light on and juddering.
sandro881
iv just had this problem, if you have replaced your plugs with new ones then they have got to be fine, it does sound liek your coils.
1. Start your engine and listen to how it ticks over, turn engine off
2. Open the bonnet, take the airbox off and take the left coil out and disconnect
3. Start the engine, is the tick over any different? If it idles worse than before, that coil is fine and working (it will idle worse because you are disconnecting a working coil). If it idles the same, that coil is dead and needs replacing (by disconnecting, it doesnt make a difference because it is already not working.
I hope this helps, if it doesnt solve your ploblem then..... errr... good luck! haha
hi, i think i got this problem on my 1.2ibiza yestarday !:( just wondering were you would get these coil packs?
thanks
