Hi guys
I just wondering wheather anyone one else has had a simalar issue ?
I own a mk2 Leon tfsi fr and last year had the following mods,
ko4 turbo conversion
s3 intercooler
s3 injectors
full tbe
dogbone mount
forge bov spacer
eibach sportlines
kmd hpfp internals
front & rear r32 brake set up with goodridge braided hoses
revo stage 3 map to accompany the mods
The car was running great smooth and plenty of power, until this point I was still using a carbon speed cai with a pipercross filter. I then sourced a itg maxogen ko4 cai and this was fitted at my garage along with a new cam follower, and a set of NGk iridium spark plugs. There was no issues with previous cam follower, but thought after 24k it would be worth changing the cam follower & spark plugs.
After fitting I took out the car for a spin and when powering down, and hitting 4-5 k the car stalled, I stopped the car switched iginition Off and back on and the engine worked fine. I did this approximately 5 times with the same result. But on the last attempt the car refused to turn over. I had the car towed back to the garage and on checking vag com, it showed fault code low fuel pressure. The garage contacted revo who stated to check whether the hpfp, had seized, they dismantled the hpfp and it all appeared in good working order. The car was taken out for a spin again with the same results.
Prior to this the car had never stalled or had any issues
any ideas ?????
s3 intercooler
s3 injectors
full tbe
dogbone mount
forge bov spacer
eibach sportlines
kmd hpfp internals
any ideas ?????
