wilkeh I think you might wanna look at Ma7ner's other thread where his entire TIP and intercooler were full of fluid...not a good thing.
Its at the garage now getting pressure tested.
BTW Ma7ner thinking this thread might have had something to do with your (huge) problem at the moment...no?
Wilkeh, as I said on first page of this thread, you'll really have to browse around where its leaking. There have been a few pointers on these 2 pages of where its most likely. Turbo if you played around with that lately (I see you have k03s. when was this done and did you replace washers?), radioter might be leaking which could be because your laguna fmic has hit something and thus hit the radiotor (nogutsnoglory had this happen to his IIRC)
also check the sensor and bottle of the actual coolant container itself.
See if you see a white/pinkish dried up residue anywhere on the block...if so there is your leak.
Lastly, top it up with water for example (cheaper) and run it till its hot, remembering not to go beyond 2 hours if thats when yours is empty lol, and see where its leaking. It will most problably start leaking only when on temp due to higher pressures
good luck and let us know
