Dump valve(Help)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I have a forge split R on my Cordoba 20VT. I was also hoping for the loud psssss sound just like the subaru, but unfortunately this was not the case. I have heard someone else describe it once as a public transportation bus opening its air pressured doors :cry: although I don't think it is that bad. It is just a soft psssh. Furthermore you have to set it to the right click (there is about 53 clicks) I believe for a regular 20VT you open it all the way and then bring it back about 16-19 clicks. If i am wrong please correct me because that would mean mine is off :whistle:
This does bring me to the next question (if that is allowed within someone elses question)
When I chip my cupra (soon) to +- 200 BHP will the psssh become louder? :confused:
And what other methods are there to increase this sound (and ofcourse the HP's? [B)])
thanks
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Uprate the filter to an open cone. Run a silicone TIP (I run a forge tip) that will increase the noise & get the ecu remapped.
More boost = more noise:D
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I didn't really understand that with the cilicone TIP and resetting the ECU...how will that increase boost?
By the way: I already have an open cone filter...
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
No not reset, remap. 'Chip' or 'remap' the ECU to increase BHP which in turn increases the 'boost'.
The silicone hose wont increase the boost but it will enhance the sound of the spool up noise and the 'whoosh' which your looking for;)
Hope this helps
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Hope this helps
Thank you for this Dan. I'm still new to this whole Turbo aspect. My first turbo car. Before this I had a 206 GTI and before that the escort rs2000, so this is a whole new world for me :funk:
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
I know what you mean, this is my 1st turbo car but after owning it for over a year Ive learnt quite abit.
I learnt nearly everything by just asking questions (most of them being on here). You soon learn:)
steve0
Drum-Masta
I have a quick question on this subject. I am soon to be hopefully purchasing my second Cupra; which already has a Forge recirc - I presume the normal 007p. It is still running the stock airbox; but with a Forge TIP, so will I get any dump noise?? I would like it, so what is best to do; buy an open cone or sell the 007p and get one of the SplitR thing's? What would be louder; the 007p with a TIP and open cone?? Or a SplitR with the same accompanying mods??
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Like I said I have a open cone filter and the forge splitR. It makes a reasonable dump sound. I still want to place a silicone TIP (which I presume is merely a replacement of the original hoses running to the DV and air filter??) and wonder what the change in sound will be then. It seems to me like people here are really pleased after having placed that.
Except why are those silicone things so damn expensive?
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
They are expensive. Some silicones are cheap but its better to stick with a trusted name like forge or samco. The quality shows in camparison with cheap products.
Im also relocating the DV using silicones and various t-pieces. This will ensure the dv and the charge will be re-directed to the cooler part of the engine. My girlfriend runs a relocation kit and a 007dv and it makes a great noise, very loud. Sounds more like a BOV.
So with me running the split r I would imagine it will be loud
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
right just changed that standard bosch one for a new forge 007p dv...Have i put it on the right way round as it aint very loud...and weres the TSSSHHH
pic:
video:
http://uk.youtube.com/watch?v=i6kUlsx6a3s
lofer
Atlantis to Interzone
Apr 11, 2007
770
Holbeach
With a standard airbox you won't hear the 007 work, your not ment to, but that doesn't sound right! Do you know anybody with vag com? :blink:
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
its not got a standard airbox its got a open cone pipercross airfilter...
My mates whos got a RST says its chattering ...not as loud as his like lol
Sounds nice tho..
plus is that the right way round as i was told that u can make it louder but turning it around
lofer
Apr 11, 2007
770
Holbeach
I’m no expert but it looks fine to me. It shouldn’t sound like that though!! Sounds like the 007 isn’t opening properly and pressure is going back through the turbo. If that is the case it will reduce the life of it dramatically! Again I don’t really know what I’m talking about so get your car looked at!!! :blink:
