I've got a 2014 mk3 ST FR 1.8TSI with the weak DQ200..
This one already has the occassional 'torque limiter reached' error and has the occassional jerky take-off..
In the future I would like to swap the OEM turbo to either an IS20 or an IS38 to increase the power, but I know this gearbox can't handle the power-increase..
I'm trying to find information on upgrading/swapping to a DQ250 or DQ380/381, but I'm not finding any usefull information on swapping gearboxes..
Does anybody have any info on swapping the DQ200 to either an DQ250 or a DQ380/1?
As far as I'm aware, I would be looking at:
different flywheel
DSG gearbox
drive-shafts(??)
starter motor mated to the chosen gearbox
shifter cable(?)
mechatronic connector
DSG coolant lines
Coding
anything else?
different flywheel
DSG gearbox
drive-shafts(??)
shifter cable(?)
DSG coolant lines
Coding
anything else?
