DPJ's Silver Leon Cupra GT - no more.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Could you not drill a very small hole in the boot floor to run a vent pipe through (In the spare wheel well), Dave?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Why not just have a thin line plumbed into the cap or a small hole in the cap to allow it to suck in the air it needs to stop it from collapsing?
The cap has a small hole in it - with a screw in plug. When the plug is screwed out - and the meth isn't running, the wmi is potentially fuming and rotting my brain (even more)
Couls you not drill a very small hole in the boot floor to run a vent pipe through (In the spare wheel well), Dave?
Yes, but then I'd have a fixed line attached to the tank. The fuel line has a quick release fitting. Now, you're going to say 'buy another one'. But I may have a one-way valve in amongst all the N112/249 pipework I ditched. Can't I try that?
Damoegan
Oct 15, 2007
8,993
Newcastle
What size pipe is it and I'll have a root around work to see if we have a one way valve kicking round.
Failing that the N249/112 pipework did have a one way valve in the system iirc. Sure my old one is sitting in the shed if its any good?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
AH, i thought this was for your screen wash tank for screen wash not WMI
Damoegan
Oct 15, 2007
8,993
Newcastle
Dave returns from loft clutching plastic one-way valve from ditched emissions pipework. (there are at least 3). It looks as though the tail from it will fit the cap vent hole sleeved with a bit of vac pipe. :thumbup:
Just the job mate :thumbup:
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Dave, in the boot, on the left hand side behind the vertical carpet/trim, there's a big(ish) bolt of polystyrene filler that comes out easy. It's not twelve litres, mind.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
It seems everything I do is function over form......... :hide:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I'm at Cadwell Park tomorrow on a trackday. Had a real rush to get the car ready. I've just driven down.....
I've fitted the safety device to cut boost if the wmi stops flowing. Unfortunately the f*ckup fairy has visited and the safety device works - but the wmi isn't running. :rolleyes: Too dark to see what's wrong now.
If I can't sort it in the morning, I'll have to switch it all off to get some decent boost..... I can't make up my mind whether to run a little bit of advance or not..... :blink:
