dpf light on after removal
chutz1
30
doncaster
i had the dpf removed and a remap about three months ago about 1 month later the dpf light came on again turned car off and on again then gone,but comes on at least 3 times a week then after could this be a bad sensor if so how could i test,also seem smokey and holding back when light comes on
kinjamin
Black Altea XL 170
May 9, 2009
159
More likely a pressure sensor issue!
GO back to the remapper to get it checked out! There should be fault codes on your car!
Kinjamin
The pressure sensor should be around £45 dont know what your mapper charges for diagnostic check!
Hope this helps!
Kinjamin
chutz1
30
doncaster
been back and no fault codes ash was at 20% so reset that ,week later back on unpluged orange senor and still came on a couple of days later,back again seonsor pluged back in ash to 0 tryed to force regen but couldnt get car to temp senors are reading same before and after dpf or would it should be.grrrrrrrr
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
The problem is with the software, the DPF removal has not been done correctly.
chutz1
30
doncaster
been back again put on vag-com ,no fault code,but there is this one in pending faults dpf sensor 1 G450 high voltage could this be the problem and does anybody have part number for the senor and digram location please
Rick @ Unicorn
The sensor does need to be in working order, as it is not just used for DPF related issued.
Rick
chutz1
30
doncaster
Had a look today and the guy who took the PDF filter off as blocked the two pipes from the sensor so now a bitstuck do I need it on the exhaust system
Rick @ Unicorn
Are the sensors still electrically connected?
Rick
Rick @ Unicorn
Ok, that's a good start. It could be that the sensor is going faulty, but, if the actual DPF light is coming on, then it hasn't been done properly I'm afraid :(
We see this issue a lot unfortunately. What year/engine is the car?
Rick
Rick @ Unicorn
What has your tuner said to you? Did they do both the remap and DPF removal?
Rick
chutz1
30
doncaster
No had the PDF.removed by some one.else made up a s/s pipe and put all the sensors back but not the pressure sensor ,then running guy did remap been back and forward with him but now think it's the blocking of pipes or the sensor is going down
Rick @ Unicorn
Get the sensors positioned as they were in the exhaust originally and go from there. We are in Stockport if you continue to struggle :)
Rick
eta76
Flying dutchman
Jan 6, 2012
77
I had the same problem. I got the same software as other Leon 1P 2007 models, but mine still had problems. Light goes on, much smoke, powerloss... So they made more changes.
Now the light still goes on, when I am in a traffic jam for half an hour. But it will not effect the performance of the car AND no more smoke.
So you probably will need your software changed..
(I have software from a dutch company JD... Not a recommendation :)
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Some tuners don't know what they doing with the Siemens PPD1.x especially when it comes to maintaining integrity of the DTC tables. ECUsafe is not the solution lol
Rich@Unicorn, are you a site sponsor?
