DOLBY's LCR...AKS Tuning Forged 14/07/2013.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Have you listened to the car with the bonnet up on idle with this hissing? Where abouts is it coming from?
wild willy
2,323
Wales
It's coming from the right hand side. I think it's the charge pipe turbo hose come lose but this is a hunch. Hopefully not worse.
You really should have checked this mate before driving on the road. Only takes around 10 seconds?
George657
479
Portsmouth
If the cars had a full rebuild by a well known tuner I wouldn't be checking for anything!
It should have been fixed properly first time!
wild willy
2,323
Wales
If your having problems with your car and a simple check is suggested it would be considered prudent to check. Alex is a very competent mechanic. I had the same problem after fitting my relentless. The problem is more pronounced when using a forge charge pipe to turbo hose without oem heat shielding in place.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Doesn't matter who did the work on a car IMO, any human being can make a mistake or simple error unintentionally.
Just give the obvious things a once over yourself. I would be doing this.
George657
479
Portsmouth
Not disagreeing with the fact a simple check would of found the problem, but judging by the price he paid, I would be pretty annoyed with the fact the vehicle has just had forged rods fitted, and has broken down!
DOLBY
2,934
98
North of London
www.facebook.com
Well I did have a look actually, i couldn't see much to the limited light at the time but because it drove ok with the hissing, I risked driving it first thing the next morning cos I had to get to work.
Yes Alex is a good me mechanic and I trust him I think it was me driving it around whilst hissing that screwed it. I drove it once. BTW.
George657
479
Portsmouth
Then you have no idea about driving a tuned car
I suggest you look into people's backgrounds before you start making statements like that! My car is Stage 2 Ready. All modifications fitted by myself. And has never failed to start or break down.
The possibility is high that a hose has just popped off. But if I had paid £XXXX for work to be carried out I would expect it to be right the first time.
I no people make mistakes and it could be 'just a hose'
But would you be saying the same if it was 'just a wheel nut'
vroomtshh
4,222
Dreghorn, Scotland
I don't need to look into anything. If you've never had a problem with a tuned car, then your a unicorn ;)
George657
479
Portsmouth
Then don't make such broad statements about people you don't no.
I had a heavily modified mk5 fiesta before my Leon.
1.7 puma engine
Phase 3 Newman cams
4-2-1 manifold sports cat
TV screen built into the headrests
Sony DVD headunit
AP coilovers
Fully polybushed
And No I did not have 1 problem with the car, call me a unicorn.
DOLBY
2,934
98
North of London
www.facebook.com
Actually I've never had a problem with my car either in the 8 years I've had it. Having NO AA roadside for 8 years is testament to that. My car has been solid. Truly solid.
Yeh it hopefully is a pipe. But it's a pipe I can't see. The reason I'm taking it up to Alex is so he can doubly check everything is ok etc etc.
It was my mistake not buying a heat shield to protect the engine parts from the new tubular manifold. Taking it on a blast would of made it shine bright white I'm sure.
Turbo cars pop hoses off for fun. I've had the Forge charge pipe pop off the turbo a few times. It's now been holding for quite a while (touch wood) since i got some JCS hi grip clips. I think mine was coming off due to the heat of the (standard) manifold allowing the jubilee clip loosen.
wild willy
2,323
Wales
IMHO this is a design fault with that particular hose, if you compare it to oem, the oem has a lip to prevent the hose slipping past the clip. When i installed the relentless the hose got so hot it started to burn, it became quite slippery and partly pulled past the clip. It was my own fault really as i had ditched the oem heat shielding and not fitted the aftermarket heat shield. Stainless manifolds radiate significantly more heat than the oem cast.
Hopefully it is a simple fix for Dolby and nothing more serious.
DOLBY
2,934
98
North of London
www.facebook.com
Yep Mr Alex has fixed her. It was indeed a boost pipe. I think we all knew this, but the question was WHERE? I did check around the bay and i couldnt see nothing. It was a boost pipe behind headlight. (In my defence) Alex did say it looked like it was on lol.
Oh well good job I knew the recovery driver.
