Devils Own Water Methanol Injection
POPOV
Newbie
Jun 25, 2005
581
Sweden
With my set up I also have 0 timing pull on all cylinders with the 98 file but on 104 I've seen above 7.
What IAT are you seeing at full WOT in comparison with the ambient temperature.
What solenoid is that by the way?
belfastchris45
445
belfast
I had a standard intercooler when i ran the logs....under partial boost i could see 4-8c bellow ambiant. On full WOT it was about + 5-10c above ambiant. I have just installed the arctic stage 2 intercooler, so expect to see ambient or bellow all the time
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
TPS screen wash is decent but not quite as effective as 50/50 real meth.
I use 50/50 with some screen wash added for "colour"
works well for me.
lasts ages.. 12psi activation for me, do3 single nozzle after interooler.
solenoid version, which I believe they have stopped selling now :(
Apr 1, 2014
865
'up anley duck'
devils own sell the quantum screen wash for £10.45 and relabel it as devils brew, then up the price by £6. If you have ever orderd it from them you can see where the label has been removed. Shame it has a quantum part number stamped underneath. :think:
cooling mist is the kit to buy, shame its from Canada.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
what colour is it?
last boost juice I saw was flourescent green... vag suff is blue
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
the boost juice is green yea. What vag stuff is green?
got a part number?
the stuff I use is blue.. intrigued as to this green stuff
thx
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
whats the vag part number underneath then fella?
POPOV
Newbie
Jun 25, 2005
581
Sweden
yes mate thats the correct kit....i tried multiple nozzles and now use a do3 in the lower throttle intake pipe, i use a bsh pipe that already has a meth bung, and a DO1 (New Nozzle) in the post TB adapter. Seems to work well with no pooling. 0 timing pull across all cylinders when using the normal file, this is a good sign the meth is getting evenly distributed across all cylinders. I also use the solenoid to stop any meth pooling
Old thread by I have a question regarding the fitting of the nozzle post TB. There are two nozzle mounting locations in the BSH throttle pipe. Did you use the one at the far end close to the IC outlet or midway on the pipe?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
do you run solenoid valve on your wmi kit?
if mounting it post throttle body vacuum will suck it out of the nozzle. The chk valve does'nt stop vacuum from sucking it out
POPOV
Newbie
Jun 25, 2005
581
Sweden
No solenoid, only used a nozzle after the TB.
So I need a solenoid, what do you use as input signal to controll it? Thanks for the heads up.
