DanGB's GTX2867 4WD Mk2 Leon Sport TFSI - New brake setup
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
Dan was ready about the guy with 507 NM of torque destroying his drive shafts, you having to do anything to stop this happening to your car?
There are guys running way more power than this in the states, I dont consider it an issue. :)
Al
7,331
9
I seriously cant wait to get a spin in your car Dan :)
Just need to figure out a good reason to get down to London :D
StuPDi
old guy
Mar 30, 2007
203
Gillingham Kent
this sounds like a serious beast now :)
i was running 360bhp in my old Impreza and it was totally spine-breaking!!
4WD was a bonus though!! how you getting the power down?? i running 155BHP diesel A4 and get the traction light on in 3rd :(
Stu
DanGB
Feb 12, 2006
3,772
London
Stu
Well the current power is a bit of a problem in the wet. I basically never put my foot down on a standstill though, I normally apply full power when im already on the move, so its not such a problem in normal driving :)
The diff im getting will help great so everyone tells me.. so looking forward to that... :)
Good news though hopefully, should have my rods tommorow or tuesday :)
60
Derby
Hi mate
Strange question but on the picture of your engine where is the vacuum hose? Is it the 1 of the 2 on the left hand side of the picture? Is that where i should be plumbing my boost gauge into?
ThanK1ng U , Chris:)
DanGB
Feb 12, 2006
3,772
London
I think they are coolant hoses mate.
I have a tap into a boost line where my forg valve used to be, its on the right hand side just underneath the end of my modded engine cover, nearer the front of the engine. I'll see if I can get some pics up.
Aug 5, 2008
60
Derby
I have a tap into a boost line where my forge valve used to be, its on the right hand side just underneath the end of my modded engine cover, nearer the front of the engine. I'll see if I can get some pics up.
U mean your old Forge Dump valve? So is the standard DV a Forge DV007p cuz my mate told me it was? And where's that? Under the engine cover??
Oh and FYI 1 of the hoses on the left is not fluid but did not provide any suction for vacuum & the other we couldn't get off :doh:
DanGB
Feb 12, 2006
3,772
London
I meant the forge Diverter valve for the FSI T engines.
The standard diverter is not forge no, its a VAG part.
The diverter valve location is sligtly different on the FR/sport and cupra engines. The diverter valve is located o the turbo in mine, but on the cupra, its at the front of the engine quite easily viable near the top, slightly to the right.
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
Forge DV007P is a 1.8T dump/diverter valve, so your mate needs to stop telling you things.
Dump/Diverter valve on the TFSI Cupra is located at the front of the engine as Dan says.
You can see below the Forge DV - FMFSITVR which is the part for the Cupra fitted to mine.
main.php
main.php
The large hose which runs from the DV round to the intake is a remote vacuum line for the DV and is standard on the Cupra.
The older TFSI like Dan's and the FR's have the DV located behind the engine on the turbo.
Forge DV's on the TFSI are a metal mechanical piston valve controlled by an electrical solenoid.
The standard VW DV is an all in one unit encompassing a built in solenoid and rubber sealed plunger.
