just done a quick search around its surprising how exspensive an uprated clutch is amd do an uprated clutch and single mass flywheel includeing fitting its £500 which i suppose isnt to bad but you cant pick supply only.
Damo, What size is the hose/where did you get it from to run a cold air feed?
As I'm sure you've already seen there is NO WHERE else to run it from and I can't be arsed to drill my headlight!
Quick question, does your TIP get hit need the bottom by a black coolant pipe. The one you need to unbolt to fit the TIP? Would be interesting to see a pick if its the same as mine.
