hi guys.. is it possible to install cruise control on a 2001 (51)
Ibiza Mk3 1.4 cool.. if yes then can somebody let me know what the part number is and send me some wiring info please..Cheers, Azz.
It was usually a case of the larger engines + Tdi only that could be retro-fitted for example the 1.4
Ibiza + 1.6 Leon never could but try the
coding first to double check but never had one work on a 1.4 yet
a note to anyone considering the kit before buying/fitting it all in there is a simple way to test if it is possible and that is by activating the cruise control code and making sure it is activated on the ecu, at least you will know before buying/fitting the kit
From Ross-tech/Vag-Com
Activating Cruise Control on a new ECU (DBW):
Factory fresh ECU's often come with cruise control de-activated. If this is the case, there will not be a letter "G" in the Component field of VAG-COM when connected to the Engine.
[Select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
After doing this procedure, there should be a letter "G" in the Component field.
hi. if your car has electronic throttle if they can install cruise control
byee
wrong - not all the car's have the software
coding capability so check it first
here's a link to genuine Golf fitting instructions that may
help
http://vwgolfr32.co.uk/ccs.pdf
